Problem with Time
Hello eveyrone,
I created a Webserver in order to change some values on a LCD screen. Now I want to put Time on my LCD screen but every time I try to get the time everything freezes. I'm using the code from the NTP example. I tried to make some changes but nothing happened. Do you know if it's possible to use a Webserver for the screen and a UDP client for the Time at the same time? If it is can you recommend a solution?
Thanks!!!
Yes.
This is going to seem obvious. Write the code correctly.
If you need help, you need to post your code.
Is the Arduino acting as a server or a client? If the Arduino is a client, why can't you just make a GET request to the server and ask for the time?
