Problem with TimeAlarms library
Hi Arduino users,
I just have a simple problem with Alarm.delay(...) in TimeAlarms library.
If I setup an alarm to 8 oclock :
Alarm.alarmRepeat(8,30,0, MorningAlarm);  // 8:30am every day
And then, in this alarm I just print "hello" then wait a delay, and print "Goodbye" :
// functions to be called when an alarm triggers:
void MorningAlarm(){
  Serial.println("Hello");
  Alarm.delay(TimeToPause);
  Serial.println("Goodbye");
Then, if I defined the wainting time to 10sec all is ok:
int TimeToPause = 10000;
But then, if I defined the waiting time to 50sec, the program wil never say goodbye.. ?? :frowning:
int TimeToPause = 50000;
I modified the TimeAlarms.h example so you can try the program and see the problem (file attached).
http://dl.free.fr/iThLXB76Z
(Of course you need TimeAlarms.h and Time.h library)
Thanks a lot for you help
Hi again,
writing my problem I get a new Idea and solved the problem .. it's just the way I setup my variable
is not valid, because an integer is smaller than 50000 I gess. changin it by long solve the problem
long TimeToPause = 50000;
Sorry... hope it will help someone.
There is no need to guess.
