Problem with timer overflow interrupts
#include <IRremote.h>
int input_pin = 2; // IR port
IRrecv irrecv(input_pin); //IR port
decode_results results;
unsigned long currentButtonCode;
unsigned long lastButtonCode;
  irrecv.enableIRIn(); // turn on IR
  pinMode(6, OUTPUT); //motor PWM signal
  pinMode(7, OUTPUT); //motor output
  pinMode(8, OUTPUT); //motor output
  timerinit();
void timerinit() {
  TCCR1A = 0x00; //Normal port operation
  TIMSK1 |= (1 << TOIE1); //enable overflow interrupts
  sei(); //enable global interrupts
void start() {
  TCNT1 = 20535; //65535-40000 from calculator
  TCCR1B = 0x0000011; //64 prescaler
void stop() {
  TCCR1B = 0x00; // (timer stopped)
ISR(TIMER1_OVF_vect) { turn off motor
  analogWrite(6, 0); //
  digitalWrite(7, LOW);
  digitalWrite(8, LOW);
  stop();
  if (irrecv.decode(&results)) {
    currentButtonCode = results.value; //ignoring reapeat 0xFFFFFF
    if (currentButtonCode == 0xFFFFFFFF) { //ignoring reapeat 0xFFFFFF
      currentButtonCode = lastButtonCode; //ignoring reapeat 0xFFFFFF
      lastButtonCode = currentButtonCode; ///ignoring reapeat 0xFFFFFF
    Serial.print(F("result = 0x")); //received code
    Serial.println(currentButtonCode, HEX); // conversion to HEX
    irrecv.blink13(true); // blink LEDs when code is received
    if (results.value == 0xFF18E7 ) { //go up
      start();
      analogWrite(6, 255); //high speed
      digitalWrite(7, HIGH); //move up
      delay(10);
    if (results.value == 0xFF4AB5) { //move down
      start();
      digitalWrite(7, LOW); //move down
      digitalWrite(8, HIGH);
      delay(10);
    if (results.value == 0xFF38C7) { //optional stop button
      analogWrite(6, 0);
      delay(10);
    irrecv.resume();
I want to control DC motor with IR remote - motor should keep rotating as long as i hold a button on remote.
I've got a problem with my timer and interrupts. My idea was to start timer everytime when the code is received from remote. Remote sends codes as long as i hold a button, so timer should keep reseting as long as i hold a button. When i release button, timer should be overflow (after few ms), so interrupt should turn off my motor.
Code works only for the first "iteration". Motor keep rotating when i hold button, but when i release button and hold it again - motor start moving and turn off immediately.
What is wrong with my idea and code? Is there any easier way to solve my problem?
You don't need a timer and interrupts... just use millis()
Get a boolean that tells you if the motor is on (motorIsON) which you set in your code when you need to go up and down and reset when you stop.
You also need an unsigned long variable (lastChrono) that you set to millis() whenever you get a remote button press.
then in the loop(), after checking for an IR event you can do
if(motorIsON  && millis() - lastChrono >= 100) {
  // stop motor
  motorStop(); // to be written, includes  motorIsON = false;
A few ms? In my calculation it's about 180ms.
What serial output do you get?
If you use the millis() call you can eliminate the use of the timer interrupt. This removes code executed in interrupt context and makes the code better readable.
Somebody experienced with clear Atmegas and AVR programming recommended me method with interrupts, thanks your help guys. I edited a code, now it looks like this:
int input_pin = 2;
unsigned long LastChrono;
boolean MotorON = 0;
  pinMode(8, OUTPUT);
    if (results.value == 0xFF18E7 ) { //GO UP
      LastChrono = millis();
      MotorON = 1;
      analogWrite(6, 255); //high speed PWM
      digitalWrite(7, HIGH); //go up
      delay(10);
    if (results.value == 0xFF4AB5) { //go down
      MotorON = 1;
      digitalWrite(7, LOW); //go down
      delay(10);
      analogWrite(6, 0);
      delay(10);
      MotorON = 0;
    if (MotorON = 1  && millis() - LastChrono >= 200) {
      MotorON = false;
      analogWrite(6, 0);
    irrecv.resume();
Something is wrong, but i am not sure what. Any suggestions?
HEX codes from button as long as i hold a button.
Maybe, i dont remember exact values from calculator :slight_smile:
ooopss (compare with what I proposed and think how to check for equality versus assignment)
(and better use true and false instead of 0 and 1 for boolean in C++)
Oooppps :slight_smile:
int input_pin = 2;
boolean MotorON = false;
  pinMode(8, OUTPUT);
      MotorON = true;
      delay(10);
      MotorON = true;
      delay(10);
      analogWrite(6, 0);
      delay(10);
      MotorON = false;
    if (MotorON == true  && millis() - LastChrono >= 200) {
      MotorON = false;
      analogWrite(6, 0);
    irrecv.resume();
Sadly, program still doesnt work as it should. When i hold a button - motor start rotating and turn off after 200ms.
Changing:
to:
if (MotorON == true  && millis() - LastChrono >=1000)
changes that motor will turn off after 1s, so something is wrong with logic.
When i press a button (1 short click), motor keeps rotating until i dont click button again :o
Remove your delay() calls, they are not needed and may disturb the other time handling.
You want to perform the test against millis() always in the loop, not just when you got a key press and why do you check results.value? don't you want to use currentButtonCode?
give meaningful names to those 6/7/8 pins. What do they represent (enablePin, forwardPin, backwardPin?)
there is no need to send again the forward oder if you are already going forward (not an issue but not "nice")
write a stop(), goUp() and goDown() function, that will make the code nicer. These functions would include the change to LastChrono and motorIsON
You could also use a switch statement
    switch (currentButtonCode) {
      case 0xFF18E7: //GO UP
        goUp();
      case 0xFF4AB5: //go down
        goDown();
      case 0xFF38C7: //optional stop button
        stop();
Yeah, You are right - fixed.
and you want to perform the test against millis() always in the loop, not just when you got a key press
like this?
millis();
I've tried to change currentButtonCode after turning on motor, so when i stop receiving new codes, currentButtonCode should have 0x000000 value, but it didnt help. Like this:
  if (currentButtonCode == 0xFF18E7 ) { // go up
      MotorON = true;
      analogWrite(6, 255); //high PWm
      currentButtonCode = 0x000000; //when no new code, currentbuttoncode is 0x00000
Sadly, my motor keep rotating even after your instructions.
   pinMode(6, OUTPUT); // PWM
  pinMode(7, OUTPUT); //motor pins
  pinMode(8, OUTPUT);
    millis(); //turning on millis
    if (currentButtonCode == 0xFF18E7 ) { //go up
      MotorON = true;
      currentButtonCode = 0x000000; //if no new code, currentbuttoncode = 0x00000
    if (currentButtonCode == 0xFF4AB5) { //go down
      MotorON = true;
      analogWrite(6, 255); //pwm
    if (currentButtonCode == 0xFF38C7) { //optional stop
      analogWrite(6, 0);
      MotorON = false;
    if (MotorON == true  && millis() - LastChrono >= 100) {
      analogWrite(6, 0);
      MotorON = false;
 irrecv.resume();
PWM pin (0-255 value, it changes speed of motor)
Digital PIN1 (go forward)
Digital PIN2 (go backward)
hardtofindanynick:
like this?
millis();
NO !!! that's totally useless. I mean check the loop() structure. if you receive a key, you do something. if you don't you loop. Ask yourself when do you want to stop the motor if there is NO key pressed for a while? where should that part of the code be? do you think there is any chance for it to work if you do that only when there is actually a key pressed?
have a look at this (typed here from your code, so totally untested)
// Motor pins
const byte speedPin  = 6; // PWM pin (0-255 value, it changes speed of motor)
const byte goUpPin   = 7; // Digital PIN1 (go forward)
const byte goDownPin = 8; // Digital PIN2 (go backward)
// IR library
const byte IRpin = 2; // input pin
const unsigned long RepeatCode  = 0xFFFFFFFF;
const unsigned long GoUpCode    = 0xFF18E7;
const unsigned long GoDownCode  = 0xFF4AB5;
const unsigned long StopCode    = 0xFF38C7;
IRrecv irrecv(IRpin);
// utilities
boolean motorIsON = false;
void goUp()
  analogWrite(speedPin, 255); //high speed
  digitalWrite(goDownPin, LOW); // better to stop one direction before activating the other one
  digitalWrite(goUpPin, HIGH); //go up
  motorIsON = true;
void goDown()
  analogWrite(speedPin, 255); //pwm
  digitalWrite(goUpPin, LOW);
  digitalWrite(goDownPin, HIGH);
  motorIsON = true;
void stop()
  analogWrite(speedPin, 0);
  motorIsON = false;
  Serial.begin(115200); // why go at 9600 bauds ?? 115200 is totally fine (can even go faster)
  pinMode(speedPin, OUTPUT);
  pinMode(goUpPin, OUTPUT);
  pinMode(goDownPin, OUTPUT);
    if (results.value == RepeatCode)  results.value = lastButtonCode; //overwrite, ignoring reapeat
    else lastButtonCode = results.value;
    switch (results.value) {
      case GoUpCode:    goUp();   break;
      case GoDownCode:  goDown(); break;
      case StopCode:    stop();   break;
    irrecv.resume();
  // is it time to stop the motor if we have not received a key for a while?
  if (motorIsON  && millis() - LastChrono >= 100) stop();
Oh man, moving
two brackets below (like in your last code) fixed my code, now it works perfectly fine! Thank you very much, i am really grateful.
Final code:
int input_pin = 2;
  irrecv.enableIRIn(); // włączenie odbierania danych
  pinMode(6, OUTPUT); //Sygnał PWM silnika nr 1
  pinMode(7, OUTPUT); //Sygnały sterujące kierunkiem obrotów silnika nr 1
  pinMode(8, OUTPUT);
void GoUp() {
  MotorON = true;
  analogWrite(6, 255); //wysoka prędkość obrotów
  digitalWrite(7, LOW); //Silnik nr 1 - roleta w dół
void GoDown() {
  MotorON = true;
  digitalWrite(7, HIGH); //Silnik nr 1 - roleta w dół
void Stop() {
  analogWrite(6, 0); //Niska prędkość obrotów
  MotorON = false;
        GoUp();
      case 0xFF4AB5: //GO DOWN
        GoDown();
      case 0xFF38C7:
        Stop();
       irrecv.resume();
    Stop();
Now that you have a working code, don't keep it ugly, use PIN numbers, use constants for the codes and indent to code (ctrl-T) ! :slight_smile:
(also don't set a pin HIGH for the direction before making sure you have put the other one to LOW - double check with my code)
usually in Arduino Land we use camelCase, function names starts with a lower cap letter and then a capital letter for each word in the name. so that would be goDown() not GoDown() for example.
