hi
i have wrote this . i expect to have 200hz pulse wave but the wave form is like the picture below .
where is my mistake ?
#include "TimerOne.h"
int n=0;
pinMode(12, OUTPUT);
Timer1.initialize(1000);
waveon();
//......................................pulse generator {pin 12} ( to drive mosphet)
void waveon() {
digitalWrite(12, LOW);
Timer1.setPeriod(200);
Timer1.attachInterrupt(waveoff);
void waveoff() {
digitalWrite(12, HIGH);
++n;
if (n = 1 ) {
Timer1.setPeriod(25);
Timer1.attachInterrupt(n1);
if (n = 2 ) {
Timer1.setPeriod(35);
Timer1.attachInterrupt(n2);
if (n = 3 ) {
Timer1.setPeriod(45);
Timer1.attachInterrupt(n3);
if (n = 4 ) {
Timer1.setPeriod(55);
Timer1.attachInterrupt(n4);
if (n = 5 ) {
Timer1.setPeriod(65);
Timer1.attachInterrupt(n5);
if (n = 6 ) {
Timer1.setPeriod(75);
Timer1.attachInterrupt(n6);
void n1() {
Timer1.setPeriod(4775);
Timer1.attachInterrupt(waveon);
void n2() {
Timer1.setPeriod(4765);
void n3() {
Timer1.setPeriod(4755);
void n4() {
Timer1.setPeriod(4745);
void n5() {
Timer1.setPeriod(4735);
void n6() {
Timer1.setPeriod(4725);
n=0;
[/td]
[/tr]
[/table]
Delta_G:
if (n = 1 ) {
Follow this link and see #3.
thank you .
i have solved it but the problem didnt solved yet.
what should i do ?
Robin2
October 24, 2017, 7:13am
5
payam2000:
what should i do ?
Post the latest version of your program.
And please post your program using the code button </> so it looks like this
. See How to use the Forum . It makes it much easier for people to help you
...R
here my latest code as you said , the problem is it do not work ! out put wave is like the picture below (12hz) instead of 200 hz ! and not stable
thank you for your help
int n=0;
pinMode(9, OUTPUT);
waveon();
void waveon() {
digitalWrite(9, LOW);
void waveoff() {
digitalWrite(9, HIGH);
++n;
if (n==1) {
if (n==2) {
if (n==3) {
if (n==4) {
if (n==5) {
if (n==6) {
void n1() {
void n2() {
void n3() {
void n4() {
void n5() {
void n6() {
n=0;
Robin2
October 24, 2017, 8:21am
7
Image from Reply #5 so we don't have to download it. See this Image Guide
...R
Robin2
October 24, 2017, 8:27am
8
IMHO something like this is a great deal simpler
if (micros() - prevPulseMicros >= intervalMicros) {
prevPulseMicros += intervalMicros;
if (pulseState == HIGH) {
digitalWrite(pulsePin, LOW);
pulseState = LOW;
intervalMicros = pulseLowMicros;
else {
digitalWrite(pulsePin, HIGH);
pulseState = HIGH;
intervalMicros = pulseHIGHMicros;
just make sure that pulseHighMicros + pulseLowMicros = 5000
...R
thank you
but i have to read out put of an opamp after 25us , 35us ,....65us after pulse is high !
and i want to use timer 1 ! i will use other timers for other things
exp:
void n6() {
// here i want to use analogread
n=0;
best regards
Robin2
October 24, 2017, 9:18am
10
Sorry, I am not familiar with that Timer1 library.
You say you want to take readings at 10 µsec intervals - but analogRead() takes 104µsecs to complete.
It would be a good idea if you describe the project you are trying to implement. At the moment this has all the hallmarks of an XY Problem
...R
