I have used digital pin 12 for GSCLK in 4x4 RGB LED shield, but the library for TLC5940 is defined with digital pin3. What changes can I made in library to work with this shield? Can anybody please help me. Thanks in advance.
If you are talking about the ethernet shield, you may have a problem with that IC. The VPRG line would normally be the slave select, but on this IC, it is more like a device enable rather than SPI enable. Maybe I am wrong, but it appears the LED output lines will float if the VPRG is HIGH. That means the LEDS will be off while your Arduino is accessing the SD or w5100.
No, I am taking about RGB LED shield (http://www.seeedstudio.com/depot/rgb-led-shield-v14-kit-p-430.html?cPath=132_134), I connected the GSCLK pin of the above shield design to digital pin 12 remaining else is same.
What digital pin was GSCLK supposed to be on? If it requires a PWM-capable pin, then D12 is not one of them.
PWM: 3, 5, 6, 9, 10, and 11.
I don't know exactly but GSCLK is used to increment the Grayscale PWM cycle with its pulse, we can make these pulses where ever required using any digital pin. I tried by giving pulses tlc_shift8() function in that library, the output is coming but some garbage values.
