Problem with TLC5940 libraries
I am using the TLC5940 library by Alex Leone
I am loading the basic usage example sketch to which I have added some code in setup() to output the digital pins to which of all the TLC pins are connected to (see the code below).
I am using a mega.
The output is this:
XLAT_PIN = 5
BLANK_PIN = 6
SIN_PIN = 2
SCLK_PIN = 1
GSCLK_PIN = 6
VPRG_PIN = 3
XERR_PIN = 4
None of these match what Arduino_Mega.h says they should be.
So what is the problem with this library or how I am using it?
I am thinking it would be easier to write my own library for TLC5940 with all the complications of TLC_config.h eliminated, and have started to do so. But the data sheet seems some what confusing to interpret. I am having trouble making my own library work too.
Does anyone know of a SIMPLE TLC5940 library that works reliably with Mega, Uno and Nano?
    Basic Pin setup:
    ------------                                  ---u----
    ARDUINO   13|-> SCLK (pin 25)           OUT1 |1     28| OUT channel 0
              12|                           OUT2 |2     27|-> GND (VPRG)
              11|-> SIN (pin 26)            OUT3 |3     26|-> SIN (pin 11)
              10|-> BLANK (pin 23)          OUT4 |4     25|-> SCLK (pin 13)
               9|-> XLAT (pin 24)             .  |5     24|-> XLAT (pin 9)
               8|                             .  |6     23|-> BLANK (pin 10)
               7|                             .  |7     22|-> GND
               6|                             .  |8     21|-> VCC (+5V)
               5|                             .  |9     20|-> 2K Resistor -> GND
               4|                             .  |10    19|-> +5V (DCPRG)
               3|-> GSCLK (pin 18)            .  |11    18|-> GSCLK (pin 3)
               2|                             .  |12    17|-> SOUT
               1|                             .  |13    16|-> XERR
               0|                           OUT14|14    15| OUT channel 15
    -  Put the longer leg (anode) of the LEDs in the +5V and the shorter leg
         (cathode) in OUT(0-15).
    -  +5V from Arduino -> TLC pin 21 and 19     (VCC and DCPRG)
    -  GND from Arduino -> TLC pin 22 and 27     (GND and VPRG)
    -  digital 3        -> TLC pin 18            (GSCLK)
    -  digital 9        -> TLC pin 24            (XLAT)
    -  digital 10       -> TLC pin 23            (BLANK)
    -  digital 11       -> TLC pin 26            (SIN)
    -  digital 13       -> TLC pin 25            (SCLK)
    -  The 2K resistor between TLC pin 20 and GND will let ~20mA through each
       LED.  To be precise, it's I = 39.06 / R (in ohms).  This doesn't depend
       on the LED driving voltage.
    - (Optional): put a pull-up resistor (~10k) between +5V and BLANK so that
                  all the LEDs will turn off when the Arduino is reset.
    If you are daisy-chaining more than one TLC, connect the SOUT of the first
    TLC to the SIN of the next.  All the other pins should just be connected
    together:
        BLANK on Arduino -> BLANK of TLC1 -> BLANK of TLC2 -> ...
        XLAT on Arduino  -> XLAT of TLC1  -> XLAT of TLC2  -> ...
    The one exception is that each TLC needs it's own resistor between pin 20
    and GND.
    This library uses the PWM output ability of digital pins 3, 9, 10, and 11.
    Do not use analogWrite(...) on these pins.
    This sketch does the Knight Rider strobe across a line of LEDs.
    Alex Leone <acleone ~AT~ gmail.com>, 2009-02-03 */
#include "Tlc5940.h"
  /* Call Tlc.init() to setup the tlc.
     You can optionally pass an initial PWM value (0 - 4095) for all channels.*/
  Tlc.init();
  Serial.print(F("XLAT_PIN = "));
  Serial.println(XLAT_PIN);
  Serial.print(F("BLANK_PIN = "));
  Serial.println(BLANK_PIN);
  Serial.print(F("SIN_PIN = "));
  Serial.println(SIN_PIN);
  Serial.print(F("SCLK_PIN = "));
  Serial.println(SCLK_PIN);
  Serial.print(F("GSCLK_PIN = "));
  Serial.println(GSCLK_PIN);
  Serial.print(F("VPRG_PIN = "));
  Serial.println(VPRG_PIN);
  Serial.print(F("XERR_PIN = "));
  Serial.println(XERR_PIN);
/* This loop will create a Knight Rider-like effect if you have LEDs plugged
   into all the TLC outputs.  NUM_TLCS is defined in "tlc_config.h" in the
   library folder.  After editing tlc_config.h for your setup, delete the
   Tlc5940.o file to save the changes. */
  int direction = 1;
  for (int channel = 0; channel < NUM_TLCS * 16; channel += direction) {
    /* Tlc.clear() sets all the grayscale values to zero, but does not send
       them to the TLCs.  To actually send the data, call Tlc.update() */
    Tlc.clear();
    /* Tlc.set(channel (0-15), value (0-4095)) sets the grayscale value for
       one channel (15 is OUT15 on the first TLC, if multiple TLCs are daisy-
       chained, then channel = 16 would be OUT0 of the second TLC, etc.).
       value goes from off (0) to always on (4095).
       Like Tlc.clear(), this function only sets up the data, Tlc.update()
       will send the data. */
    if (channel == 0) {
      direction = 1;
      Tlc.set(channel - 1, 1000);
    Tlc.set(channel, 4095);
    if (channel != NUM_TLCS * 16 - 1) {
      Tlc.set(channel + 1, 1000);
      direction = -1;
    /* Tlc.update() sends the data to the TLCs.  This is when the LEDs will
       actually change. */
    Tlc.update();
    delay(75);
Don't print these values, they don't contain Arduino pin numbers but bit numbers of the corresponding output registers. Only the combination of XLAT_PIN, XLAT_PORT and XLAT_DDR make sense, the XLAT_PIN for itself doesn't make any sense.
Do you know the one by Paul Stoffregen?
pylon:
OH! You are supposed to use those digitalPinTo....() macros or functions.
What is the correct one to convert output registers to digital pins then?
Either way I can seem to get any of the libraries to work with an Arduino Nano.
It sort of works briefly with a mega if I fiddle with the wires and then seems to die out. Not sure what is going on there.
I am thinking I want to write my own library anyway because all the existing libraries seem so friggin complicated when it appears to me they don't need to be.
I ended up finding this: Demystifying the TLC5940 - artcfox and it shows my interpretation of the data sheet is correct so far.
I am unclear about the GS cycle though.
Why does the library use a timer to create GSCLK pulses to update the state of the LEDs when it appears a for loop with pulse pin would do for one cycle at a time?
And why a timer to produce multiple XLAT pulses when only one is needed according to the data sheet?
