Hi group,
I have got a problem with setting the colon on a TM1637Display.
I can set the colon with that code:
// set ":" between segments 2&3.
byte segto;
int value = 1244;
segto = 0x80 | display.encodeDigit((value / 100) % 10);
display.setSegments(&segto, 1, 1);
The problem is that it is overwritten with the next commands:
display.showNumberDec(A0dB / 10, false, 2, 0);
display.showNumberDec(A1dB / 10, false, 2, 2);
Do you know a way to write on the display without resetting the colon?
I have found that code which is not accepted by my library:
display.setColon(true)
With which library would that work?
Thank your for your advice.
Laszlo
