Problem with toCharArray
Hello.
I have a problem understanding strange behavior of string.
After ussing toCharArray old string appears in my variables.
Need for:
I get a string variable from Function1 and need this variable for Function2, which acceps char* variable.
What I'm doing wrong?
Thank you for help.
Code which represents the problem:
String st;
char* cha;
  st="Test";
  Serial.print("st1:");
  Serial.println(st);
  cha="";
  Serial.print("ch1:");
  Serial.println(cha);
  Serial.println("");
  st.toCharArray(cha,st.length()+1);//PROBLEM LINE
  Serial.print("cha2:");
  cha="Mhh";
  Serial.print("cha3:");
  st="";
  Serial.print("st2:");
  Serial.println(st);
  Serial.println("");
Serial monitor with problem line (NOT OK):
st1:Test
ch1:
cha2:Test
Testcha3:Mhh
Testst2:
TestTest
Test
Serial monitor without problem line (OK):
st1:Test
ch1:
cha2:
cha3:Mhh
st2:
You need to allocate space. cha is currently a pointer basically pointing to nowhere. Next it points to an empty string (1 byte) and next you dump N bytes in there overwriting part of uour memory.
Just use something like char cha[100] instead of char *cha.
And even better, get rid if String (capital S) and work with the cha array directly.
Thank you very much.
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. Just use cstrings - char arrays terminated with 0.
...R
Strings = evil
