Problem with touch screen
I would like to use the touch screen here:https://www.aliexpress.com/item/1pcs-J34-F85-240x320-2-8-SPI-TFT-LCD-Touch-Panel-Serial-Port-Module-with-PCB/32795636902.html?spm=2114.01010208.3.20.nfQWvC&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10150_10068_10136_10137_10138_10060_10062_10141_10056_10055_10054_128_10059_10099_10103_10102_10096_10148_10147_10052_10053_10050_10107_10142_10051_10143_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10037_10032_10078_10079_10077_10073_10070_10123_10124-10050,searchweb201603_2,afswitch_1,ppcSwitch_7&btsid=16d4cbf1-8fcf-44a9-a3e1-dc49f84f88a2&algo_expid=5192b7ef-1ded-47cd-8b6e-147d931b3d71-2&algo_pvid=5192b7ef-1ded-47cd-8b6e-147d931b3d71
The problem is that i can't find any datasheet (or a driver) from the seller. Is anybody how can help me??
It is a regular SPI ILI9341 screen with an XPT2046 touch controller. There is also an SD card cage.
All three components are SPI and can fit on the same 3.3V SPI bus.
Life is simpler with a Zero, Due, STM32, ... board because they run at 3.3V
If you want to use a 5V Uno or 5V Mega you need to provide level shifters for every signal line.
The XPT2046 works exactly like all the other SPI Touch controller chips e.g. ADS7843. Note that you can't use URTouch library with a real SPI bus.
David.
