Problem with two Serial communication
i have these two sketches in my arduino. one is sketch is for reading serial numbers sent by an rfid reader and the other is turning an LED on by sending a letter in my serial monitor/PC application.
The RFID code came from Seedstudio
#include <SoftwareSerial.h>
String msg;
char inChar;
int x;
SoftwareSerial Rfid(2, 3);    // RX as pin 2
 Rfid.begin(9600);
while (inChar = Rfid.read() != 2)    // Wait for start byte from Rfid reader when tag is swiped
msg = "";
for (x = 0; x < 12; x++)
    delay(10);
    inChar = Rfid.read();
    msg += inChar;
Serial.print(msg);    // Sends the ID plus the checksum byte (12 bytes)
2nd sketch LED on:
int ledpin = 9;
byte byteread
 pinMode (9,OUTPUT);
  if (Serial.available()) {
    byteread = Serial.read();
   if (byteRead == '1'){
     digitalWrite(9,HIGH);
    delay(3000);
   digitalWrite(9,LOW);}
Problem: when i combine the two codes together, i only get the reading from the rfid reader, and when I send the number 1, it doesnt turn on the led, Can anyone help me with these serial events?
That's a pretty lousy way to read serial data. You know what the start of the packet marker is. There is an end of packet marker, too, You can't just cross your fingers and hope all the data arrives while you are diddling around.
I can't see your attempt to combine the two sketches. I'd guess that you left something important out.
