Problem with twodimensional array
I have got this programm which demonstates my problem which I have stuck during another project.
int data [6][100];
int rotation = 0;
  delay(3000);
Serial.println("test");
void loop () {
  Serial.println(rotation);
  data[6][rotation]  = 42;
On the serial monitor it produces the following output:
test
0
0
42
42
42
42
42
42
42
42
42
42
42
42
42
42
42
(etc.)
In my imagination the line "data[6][rotation] = 42; " should assign the value "42" to the data array at position [6][rotation] which would be [6][0] .
but after the first run of the loop() function it appears that the value of the variable "rotation" has changed to 42. So I assume that this line "data[6][rotation] = 42; " is not doing what I am assuming.
Could you please help me ?
Marc
The problem is the "6". That position don't exist in the array. Try:
  data[5][rotation]  = 42;
Thank you very much! I thought if i write data[6] it would be from 0-6 .Always confusing me , thank you again and forgive me this stupid mistake.
