Hi all,
I am in the process of cleaning up a program I am working with, basically it was just one long sketch, and now I am putting components in separate libraries. I encountered a problem in the process that seems simple but I can't fix. I am using an array containing unsigned longs, as a kind of lookup table for a segment display with several shift registers. In the sketch these arrays worked fine, but in the libraries they don't. This is my first attempt at making libraries so that will likely have a lot to do with this problem.
Anyway, when I Serial print the values from the array completely different values come out. I thought perhaps this has something to do with libraries handling unsigned long inside arrays differently than arduino sketches, but I couldn't find anything by googling. Here are the sketch and the libraries:
Sketch:
#include "Display.h"
Display mydisplay(6,9,10); // dataPin_BlueLed = 6, // latchPin_GreenLed = 9, clockPin_RedLed = 10
mydisplay.output(0,0);
Header of library:
Video_control - Library for showing display values with different displays on the Pursuit Wristband.
#ifndef Display_h
#define Display_h
#include "Arduino.h"
class Display
public:
Display(int dataPin_BlueLed, int latchPin_GreenLed, int clockPin_RedLed);
void output(int displaydata, uint8_t displayType);
private:
void OutputSegment();
int _dataPin;
int _latchPin;
int _clockPin;
unsigned long FirstDigit[];
unsigned long SecondDigit[];
unsigned long Segmentoutput;
#endif
Source of library:
Display::Display(int dataPin_BlueLed, int latchPin_GreenLed, int clockPin_RedLed)
pinMode(clockPin_RedLed, OUTPUT);
pinMode(latchPin_GreenLed, OUTPUT);
pinMode(dataPin_BlueLed, OUTPUT);
_dataPin_BlueLed = dataPin_BlueLed;
_latchPin_GreenLed = latchPin_GreenLed;
_clockPin_RedLed = clockPin_RedLed;
//*** Arrays for Segment display
unsigned long FirstDigit[12] ={
339738624, 392691712, 471859200, 354418688, 386400256, 352583680, 335806464, 392167424, 335544320, 352321536, 527171584, 470024192 };
unsigned long SecondDigit[13] ={
2147614722, 3758309378, 2147549187, 2684420098, 3758112770, 2684362754, 2147491842, 3758292994, 2147483650, 2684354562, 3758317571, 3221364737, 3221225475 };
void Display::output(int displaydata, uint8_t displayType){
_displaydata = displaydata;
_displayType = displayType;
for (int i = 0; i < 12; i++) {
Serial.print(i);
Serial.print(": ");
Serial.println(FirstDigit[i]);
for (int i = 0; i < 13; i++) {
Serial.print(i);
Serial.print(": ");
Serial.println(SecondDigit[i]);
So I was expecting to find the values of the array in the serial monitor, but instead I got three times zero, then a small number like 412, etc. Anyone an idea what might be wrong?
