Problem with Updating ESP32 Firmware through External Web Server
hi i tried the OTA programming with making a web server and connecting to it using my phone and it worked now I'm trying to do the OTA programming for my esp32 using a external web server. when i run the code the esp32 connects to WiFi but it can't download the firmware and gives an error when i use the link with https it shows 303 error when i change it to http it shows 302 error and when i delete the http from the link it shows this error "failed to parse protocol HTTPClient.cpp:251"
here is my code what is the problem?
#include <WiFi.h>
#include <HTTPClient.h>
#include <Update.h>
void updateFirmware(uint8_t *data, size_t len);
// location of firmware file on external web server
// change to your actual .bin location
#define HOST "www.drive.google.com/uc?export=download&id=1CGPNlpRMR9VKpC6HS3vWJtr4JCS6gB6Q"
HTTPClient client;
// Your WiFi credentials
const char* ssid = "abdc";
const char* password = "8765";
// Global variables
int totalLength;       //total size of firmware
int currentLength = 0; //current size of written firmware
  // Start WiFi connection
  WiFi.mode(WIFI_MODE_STA);
  WiFi.begin(ssid, password);
      Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  // Connect to external web server
  client.begin(HOST);
  // Get file, just to check if each reachable
  int resp = client.GET();
  Serial.print("Response: ");
  Serial.println(resp);
  // If file is reachable, start downloading
  if(resp == 200){
      // get length of document (is -1 when Server sends no Content-Length header)
      totalLength = client.getSize();
      // transfer to local variable
      int len = totalLength;
      // this is required to start firmware update process
      Update.begin(UPDATE_SIZE_UNKNOWN);
      Serial.printf("FW Size: %u\n",totalLength);
      // create buffer for read
      uint8_t buff[128] = { 0 };
      // get tcp stream
      WiFiClient * stream = client.getStreamPtr();
      // read all data from server
      Serial.println("Updating firmware...");
      while(client.connected() && (len > 0 || len == -1)) {
           // get available data size
           size_t size = stream->available();
           if(size) {
              // read up to 128 byte
              int c = stream->readBytes(buff, ((size > sizeof(buff)) ? sizeof(buff) : size));
              // pass to function
              updateFirmware(buff, c);
              if(len > 0) {
                 len -= c;
           delay(1);
  }else{
    Serial.println("Cannot download firmware file. Only HTTP response 200: OK is supported. Double check firmware location #defined in HOST.");
  client.end();
void loop() {}
// Function to update firmware incrementally
// Buffer is declared to be 128 so chunks of 128 bytes
// from firmware is written to device until server closes
void updateFirmware(uint8_t *data, size_t len){
  Update.write(data, len);
  currentLength += len;
  // Print dots while waiting for update to finish
  Serial.print('.');
  // if current length of written firmware is not equal to total firmware size, repeat
  if(currentLength != totalLength) return;
  Update.end(true);
  Serial.printf("\nUpdate Success, Total Size: %u\nRebooting...\n", currentLength);
  // Restart ESP32 to see changes
  ESP.restart();
That the OTA client doesn't expect to be redirected. Services as Google Drive aren't simple web servers but web applications that expect a browser to be used for access. Put your firmware to a simple webserver and it probably works.
do you know any free simple web server that provides direct link ?
Apache and Nginx are two free web servers that can server any content. You can install them on your PC as they are available for all common operating systems.
i used another server and the problem was solved and i did OTA update i used this site https://uupload.ir/
Did you change the Arduino's code?
i only changed the define host part.
What ESP32 did you use it?
i used esp32WROOM
