Problem: When trying to upload a sketch via the USB Programming Port the following error message appears:
No device found on /dev/tty.usbmodem1421
However, when I connect the Arduino via the Native USB Port the sketch is uploaded and runs just fine.
To my understanding, I have selected the Board and the Port correctly each time.
I am using an Arduino Due, Arduino IDE 1.5.4 and Mac OS 10.9 (Mavericks).
The same problem has been described by "aude" here: http://forum.arduino.cc//index.php?topic=148613.msg1442629#msg1442629
In his case the problem was solved setting the Baud rate manually.
Would the problem in my case also be the Baud rate? If yes, how do I change it on a Mac?
Is that an Arduino IDE software bug or is it meant to be that way?
piershaw, that sounds very good! Could you explain to me where exactly I can find these FTDI files and what I have to do with them? I thought there are no drivers to be installed for Mac OS. ?
I saw that the FTDI files are mentioned in the Windows installation instructions, but on the Mac I can't see any Arduino folder with such files.
Well, Due doesn't use an FTDI chip, so that won't help any. The driver for the 16u2 chip used instead SHOULD be built into the Mac. (it would show as /dev/usbmodem* instead of /dev/usbserial*, but that shouldn't fool the Arduino menu.) When you say "programming port", you mean the one closest to the power jack, right?
So should the problem be related to the 16u2 driver?
However, I have no problem finding and selecting the /dev/tty.usbmodem1411 in the Ports menu in the Arduino IDE.
This issue is really causing me headaches. :~
I have three arduino Uno boards, a Make: brand a genuine Arduino Uno and a 3rd party R3.
After spending a solid week of my precious free time going through at least 30 different solutions trying to install /dev/tty.usbmodemXXXX The best I was able to do was program 'blink' with /dev/cu.usbmodemXXXX. Any other program fails miserably.
I finally solved the problem. I bought a cheap PC to program the Arduino. Thanks Apple!! /
