Problem with uploading a sketch to a floppy disk
I have a problem, the sketch is good, but when I try to load it, it displays to me
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\gzibe\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 3
     Firmware Version: 4.4
     Vtarget         : 0.3 V
     Varef           : 0.3 V
     Oscillator      : 28.800 kHz
     SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\gzibe\AppData\Local\Temp\arduino_build_149280/sketch_aug03b.ino.hex"
avrdude: writing flash (2044 bytes):
Writing | ################################################## | 100% 0.31s
avrdude: 2044 bytes of flash written
avrdude: verifying flash memory against C:\Users\gzibe\AppData\Local\Temp\arduino_build_149280/sketch_aug03b.ino.hex:
avrdude: load data flash data from input file C:\Users\gzibe\AppData\Local\Temp\arduino_build_149280/sketch_aug03b.ino.hex:
avrdude: input file C:\Users\gzibe\AppData\Local\Temp\arduino_build_149280/sketch_aug03b.ino.hex contains 2044 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.24s
avrdude: verifying ...
avrdude: 2044 bytes of flash verified
avrdude done. Thank you.
And it does with each pin, but when I run pin 13 high, the floppy disk works normally
Floppy disk?
Is pin 13 on the Arduino? How is it adjusted "high?" A command? A pullup? Have you thought of using papertape instead?
There is nothing wrong with the upload. You see this additional information because you have enabled show verbose output during upload in file->preferences.
If you have problems with your sketch, you will have to post it (please don't forget to use code tags as described in How to get the best out of this forum) , describe what it's supposed to do and what actually does. If additional hardware is involved, please provide a wiring diagram / schematic; photo of a hand drawn one is fine.
