Hi, sorry in advance as I'm still a newbie with Arduino.
I was controlling a servo using my arduino uno board (it's a prototype board with each digital pin having all three ports, V, G, and S) when all of a sudden the servo started acting weird so I unplugged right away. The wiring was correct, I'm sure I didn't short out anything as the wires were connected correctly. I was powering the servo directly from the usb 5v port.
Ever since then, the uno board no longer works. I can't upload any new codes, nor does the reset button on the uno board works.
Here's the error message:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
Archiving built core (caching) in: /var/folders/sp/rv7xmw3n14394dqtcwh78sh40000gp/T/arduino_cache_644051/core/core_arduino_avr_uno_51f02b7210b938436b779d1c032618e1.a
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem141241 -b115200 -D -Uflash:w:/var/folders/sp/rv7xmw3n14394dqtcwh78sh40000gp/T/arduino_build_355021/sketch_may07a.ino.hex:iavrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/peterhan/.avrduderc"
User configuration file does not exist or is not a regular file, skippingUsing Port : /dev/cu.usbmodem141241
Using Programmer : arduino
Overriding Baud Rate : 115200This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Any help will be greatly appreciated. I have an UsbTinyISP bootloader ready to go but it doesn't seem to be the problem. Is this board done for good?
