Problem with uploading board
RepRap Mendel, using boards Generation 3 Electronics from TechZone.
Problem with upload firmware to the Extruder Board (controller Atmega168):
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
How to solve the problem?
Sofware - Arduino 0018
We are having the same issue, just got this for my sons birthday and I am lost.. he wants it going NOW!!! so any help would be great. Thanks!
Dear Users,
it is almost impossible to give more than just general tips if You don't provide a minimum set of information.
  • Operating System
  • Software version
  • Hardware setup
Make sure the drivers are installed and actually work.
Even though the Arduino and relatives come preloaded with a bootloader, my personal recommendation is to get a dedicated AVR programmer as well. Affordable ones for less than 30$ work just fine and can save you many headaches.
And it's about time to get a sticky post for this topic.
A datasheet for whatever a Reprap is would help as well ;) I found the website, but other than prices and pictures there isn't a lot on there......
I solved the problem. Bootloader in Generation 3 Electronic from TechZone has certain characteristics. For correct uploading is need press button "Reset" on board, run uploading and release button "Reset" ONLY AFTER Arduino write: "Binary sketch size: 7054 bytes (of a 14336 byte maximum)" (or something like that). In this variant all will Ok.
