problem with uploading code to adafruit pro trinket using uno(FIXED)
I am having a problem with uploading code to an adafruit pro trinket using an Arduino Uno with the processor removed. I am using the FTDI headers on the pro trinket.
This is the error message: System wide configuration file is "/private/var/folders/63/g2plmkrj6zl_nr7g2fr4lgqh0000gq/T/AppTranslocation/EDDADD75-3416-4779-A75A-1FA54F9AF8AD/d/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/fablab/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1421
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Please help!
Seeing that you seem to have fixed the issue, can you post the solution in case others encounter the same problem?
