Problem with uploading to arduino mini
Hello forum,
I am having problem in uploading code to my arduni mini, please help.
thanks,
Arduino: 1.6.8 (Windows 10), Board: "Arduino Mini, ATmega328"
Sketch uses 1,066 bytes (3%) of program storage space. Maximum is 28,672 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes. avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0c avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0c Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. Invalid library found in C:\Users\Parker\Documents\Arduino\libraries\Adafruit_NeoPixel: C:\Users\Parker\Documents\Arduino\libraries\Adafruit_NeoPixel Invalid library found in C:\Users\Parker\Documents\Arduino\libraries\Adafruit_NeoPixel: C:\Users\Parker\Documents\Arduino\libraries\Adafruit_NeoPixel
That's not a lot of info you give us...
What do you use to upload? Has it a DTR line? Does that device show correct (without ! ) in device manager (assuming Windows because you didn't tell us)? How did you connect it? What did you select in Arduino IDE?
Etc, all some basics...
