Hello , I’m aiming to control a motor by using the ps3 controller . But at the start I just wanted to cheek if I can control an led . So I used the usb host library and modified the program so that when I press the X on the controller the LED should be high . but when I do that nothing happens !!!
Can some one explain what is going wrong ? I’m a beginner in arduino so I would really appreciate your help
Here is the code
Example sketch for the PS3 USB library - developed by Kristian Lauszus
For more information visit my blog: http://blog.tkjelectronics.dk/ or
send me an e-mail: kristianl@tkjelectronics.com
#include <PS3USB.h>
USB Usb;
int led = 13;
/* You can create the instance of the class in two ways */
PS3USB PS3(&Usb); // This will just create the instance
//PS3USB PS3(&Usb,0x00,0x15,0x83,0x3D,0x0A,0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
boolean printAngle;
uint8_t state = 0;
pinMode(led, OUTPUT);
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while(1); //halt
Serial.print(F("\r\nPS3 USB Library Started"));
Usb.Task();
if(PS3.PS3Connected || PS3.PS3NavigationConnected) {
if(PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
Serial.print(F("\r\nLeftHatX: "));
Serial.print(PS3.getAnalogHat(LeftHatX));
Serial.print(F("\tLeftHatY: "));
Serial.print(PS3.getAnalogHat(LeftHatY));
if(!PS3.PS3NavigationConnected) {
Serial.print(F("\tRightHatX: "));
Serial.print(PS3.getAnalogHat(RightHatX));
Serial.print(F("\tRightHatY: "));
Serial.print(PS3.getAnalogHat(RightHatY));
// Analog button values can be read from almost all buttons
if(PS3.getAnalogButton(L2) || PS3.getAnalogButton(R2)) {
Serial.print(F("\r\nL2: "));
Serial.print(PS3.getAnalogButton(L2));
Serial.print(F("\tR2: "));
Serial.print(PS3.getAnalogButton(R2));
if(PS3.getButtonClick(PS))
Serial.print(F("\r\nPS"));
if(PS3.getButtonClick(TRIANGLE))
Serial.print(F("\r\nTraingle"));
if(PS3.getButtonClick(CIRCLE))
Serial.print(F("\r\nCircle"));
if(PS3.getButtonClick(CROSS))
digitalWrite(led, HIGH);
if(PS3.getButtonClick(SQUARE))
Serial.print(F("\r\nSquare"));
if(PS3.getButtonClick(UP)) {
Serial.print(F("\r\nUp"));
PS3.setAllOff();
PS3.setLedOn(LED4);
if(PS3.getButtonClick(RIGHT)) {
Serial.print(F("\r\nRight"));
PS3.setAllOff();
PS3.setLedOn(LED1);
if(PS3.getButtonClick(DOWN)) {
Serial.print(F("\r\nDown"));
PS3.setAllOff();
PS3.setLedOn(LED2);
if(PS3.getButtonClick(LEFT)) {
Serial.print(F("\r\nLeft"));
PS3.setAllOff();
PS3.setLedOn(LED3);
if(PS3.getButtonClick(L1))
Serial.print(F("\r\nL1"));
if(PS3.getButtonClick(L3))
Serial.print(F("\r\nL3"));
if(PS3.getButtonClick(R1))
Serial.print(F("\r\nR1"));
if(PS3.getButtonClick(R3))
Serial.print(F("\r\nR3"));
if(PS3.getButtonClick(SELECT)) {
Serial.print(F("\r\nSelect - "));
Serial.print(PS3.getStatusString());
if(PS3.getButtonClick(START)) {
Serial.print(F("\r\nStart"));
printAngle = !printAngle;
if(printAngle) {
Serial.print(F("\r\nPitch: "));
Serial.print(PS3.getAngle(Pitch));
Serial.print(F("\tRoll: "));
Serial.print(PS3.getAngle(Roll));
else if(PS3.PS3MoveConnected) { // One can only set the color of the bulb, set the rumble, set and get the bluetooth address and calibrate the magnetometer via USB
switch(state) {
case 0:
PS3.moveSetRumble(0);
PS3.moveSetBulb(Off);
state = 1;
case 1:
PS3.moveSetRumble(75);
PS3.moveSetBulb(Red);
state = 2;
case 2:
PS3.moveSetRumble(125);
PS3.moveSetBulb(Green);
state = 3;
case 3:
PS3.moveSetRumble(150);
PS3.moveSetBulb(Blue);
state = 4;
case 4:
PS3.moveSetRumble(175);
PS3.moveSetBulb(Yellow);
state = 5;
case 5:
PS3.moveSetRumble(200);
PS3.moveSetBulb(Lightblue);
state = 6;
case 6:
PS3.moveSetRumble(225);
PS3.moveSetBulb(Purble);
state = 7;
case 7:
PS3.moveSetRumble(250);
PS3.moveSetBulb(White);
state = 0;
