My W5200 (v2.1) Ethernet shield from seedstudio works fine on an UNO but it won’t compile for the DUE (R3)
Anybody got this to work?
Code is the chatserver tutorial that comes with the W5200
I followed the instruction from here Ethernet Shield V2.0 | Seeed Studio Wiki
And it works ok for the uno, but not for the due.
Help appreciated!
Errors (log) below:
Arduino: 1.5.6-r2 (Windows 7), Board: "Arduino Due (Programming Port)"
Using library EthernetV2_0 in folder: C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0 (legacy)
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\sam\libraries\SPI (legacy)
C:\Program Files (x86)\Arduino/hardware/tools/g++arm_none_eabi/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=156 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E_ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\system/libsam -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/CMSIS/Include/ -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/Device/ATMEL/ -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\variants\arduino_due_x -IC:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0 -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\libraries\SPI C:\Users\xxxxx\AppData\Local\Temp\build1674528417543249285.tmp\bjorn_ChatServer_uno.cpp -o C:\Users\xxxxx\AppData\Local\Temp\build1674528417543249285.tmp\bjorn_ChatServer_uno.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/g++arm_none_eabi/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=156 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E_ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\system/libsam -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/CMSIS/Include/ -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/Device/ATMEL/ -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\variants\arduino_due_x -IC:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0 -IC:\Program Files (x86)\Arduino\hardware\arduino\sam\libraries\SPI -IC:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\DhcpV2_0.cpp -o C:\Users\xxxxx\AppData\Local\Temp\build1674528417543249285.tmp\EthernetV2_0\DhcpV2_0.cpp.o
In file included from C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\DhcpV2_0.cpp:4:
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h: In static member function 'static void W5100Class::initSS()':
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h:357: error: 'DDRB' was not declared in this scope
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h:357: error: '_BV' was not declared in this scope
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h: In static member function 'static void W5100Class::setSS()':
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h:358: error: 'PORTB' was not declared in this scope
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h:358: error: '_BV' was not declared in this scope
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h: In static member function 'static void W5100Class::resetSS()':
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h:359: error: 'PORTB' was not declared in this scope
C:\Users\xxxxx\Documents\Arduino\libraries\EthernetV2_0\utility/w5200.h:359: error: '_BV' was not declared in this scope
code:
#include <DhcpV2_0.h>
#include <DnsV2_0.h>
#include <EthernetClientV2_0.h>
#include <EthernetServerV2_0.h>
#include <EthernetUdpV2_0.h>
#include <EthernetV2_0.h>
#include <utilV2_0.h>
Chat Server
A simple server that distributes any incoming messages to all
connected clients. To use telnet to your device's IP address and type.
You can see the client's input in the serial monitor as well.
Using an Arduino Wiznet Ethernet shield.
Circuit:
- Ethernet shield attached to pins 10, 11, 12, 13
- Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
//#include <EthernetV2_0.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
//IPAddress ip(192,168,1, 177);
//IPAddress gateway(192,168,1, 1);
//IPAddress subnet(255, 255, 0, 0);
IPAddress ip(172,20,1, 10);
IPAddress gateway(172,20,1, 1);
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
#define W5200_CS 10
#define SDCARD_CS 4
pinMode(SDCARD_CS,OUTPUT);
digitalWrite(SDCARD_CS,HIGH);//Deselect the SD card
// initialize the ethernet device
Ethernet.begin(mac, ip, gateway, subnet);
// start listening for clients
server.begin();
while (!Serial)
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Chat server address:");
Serial.println(Ethernet.localIP());
while (true)
// wait for a new client:
// when the client sends the first byte, say hello:
if (client)
if (!alreadyConnected)
// clead out the input buffer:
client.flush();
Serial.println("We have a new client");
client.println("Hello, client!");
alreadyConnected = true;
if (client.available() > 0)
// read the bytes incoming from the client:
char thisChar = client.read();
// echo the bytes back to the client:
server.write(thisChar);
// echo the bytes to the server as well:
Serial.write(thisChar);
if (thisChar == 'Q')
