Hello, after using the help of the members of this forum I have succed to control
two engine with wifi card (arduino wifi shield http://arduino.cc/en/Main/ArduinoWiFiShield) and
the motor card (arduino motor shield http://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/?ALLSTEPS) but the problem in pin 9 since it is reserved for wifi card so it presents an error
who can help me ,for exemple I can change the motor 2 to
work with another pin or anything, I need your help
this is my arduino code
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "mon reseau wifi"; // your network SSID (name)
char pass[] = "mon mot de passe"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
Serial.begin(9600); // initialize serial communication
pinMode(22, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
//establish motor brake pins
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
//Turns brake off for drive motor
digitalWrite(9, HIGH);
digitalWrite(8, HIGH);
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true); // don't continue
String fv = WiFi.firmwareVersion();
if ( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
printWifiStatus(); // you're connected now, so print out the status
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("<a href=\"/F\">AVANT</a>
client.print("<a href=\"/B\">ARRIERE</a>
client.print("<a href=\"/D\">DROITE</a>
client.print("<a href=\"/G\">GAUCHE</a>
client.print("<a href=\"/A\">ARRET</a>
client.print("<a href=\"/N\">MODE NUIT</a>
client.print("<a href=\"/J\">MODE JOUR</a>
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check the client request
if (currentLine.endsWith("GET /F")) {
digitalWrite(12, HIGH);
digitalWrite(13, HIGH);
digitalWrite(9, LOW);
digitalWrite(8, LOW);
analogWrite(3, 200);
analogWrite(11, 200);
if (currentLine.endsWith("GET /A")) {
if (currentLine.endsWith("GET /B")) {
digitalWrite(12, LOW);
digitalWrite(13, LOW);
analogWrite(3, 123);
analogWrite(11, 123);
if (currentLine.endsWith("GET /D")) {
if (currentLine.endsWith("GET /G")) {
if (currentLine.endsWith("GET /N")) {
digitalWrite(22, HIGH);
if (currentLine.endsWith("GET /J")) {
digitalWrite(22, LOW);
// close the connection:
client.stop();
Serial.println("client disonnected");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
