Problem with writing and reading unsigned long to EEPROM
Hello,
I'm trying to write a program that stores a timestamp (in unixtime format) on the arduino EEPROM when a wicking event happens. I used EEPROM.put and EEPROM.get to write and read the timestamp from the EEPROM and so far the serial monitor displays the correct value. However, when I try to read the EEPROM with avrdude through cmd, I get gibberish and an obviously wrong Hexadecimal values. What am I missing here?
Here is my entire code:
#include <Wire.h>
#include "RTClib.h"
#include <EEPROM.h>
RTC_DS3231 rtc;
int probeValue;
int address = 0;
  delay (3000); // 3 sec delay for console opening
  Wire.begin();
  if (! rtc.begin())
    Serial.println("RTC not connected. Double check connection.");
    while (1);
  if(rtc.lostPower())
    Serial.println ("Adjusting RTC time...");
    rtc.adjust(DateTime(F(__DATE__),F(__TIME__)));    // Adjusts the RTC time to the time and date the sketch was compiled
  DateTime now = rtc.now();
  probeValue = analogRead(A0);
  float voltage = probeValue*(5.0/1023.0);
  Serial.println (voltage);
  delay (20);
  /*Recording the TimeStamp to the EEPROM - triggered by wicking*/
  if (voltage > 0.06)
   Serial.println ("Timestamp Taken at");
   Serial.print (now.unixtime());
   Serial.print (" seconds");
   Serial.println(" since midnight of 1/1/1970");
   Serial.println("which in Human Readable date and time is");
   Serial.print(now.year());
   Serial.print("/");
   Serial.print(now.month());
   Serial.print("/");
   Serial.print(now.day());
   Serial.print(" ");
   Serial.print(now.hour());
   Serial.print(":");
   Serial.print(now.minute());
   Serial.print(":");
   Serial.println(now.second());
   Serial.println(" ");
   unsigned long timestamp = {now.unixtime()};
   Serial.println("writing TimeStamp (in unixtime) to the EEPROM...");
   EEPROM.put(address, timestamp);
   delay(2000);
   Serial.println("verifying TimeStamp...");
   Serial.println(EEPROM.get(address, timestamp));
   while(1);
  {Serial.println ("Waiting for sample to be taken.");
  delay(5000);
   return;
and this is what I get from the serial monitor:
vs. what I get from cmd:
Does anyone has any idea what's going on?
https://www.google.com/search?q=convert+0x58e641fc+to+decimal
Anything look familiar?
oh wow, I don't know what I was thinking converting it to ASCII when it's actually decimal. Sorry for this stupid question and thank you so much! :smiley:
You are welcome.
