Dear forum members.
My name is Bas de Boer. Love using arduino and making projects with it. Only this time i have a little problem with the code.
I'm making analog RGB strips light to my bedroom. And i want to use 2 rotary encoders and 2 switches for 2 RGB strips. One encoder and switch for one strip
The project is like this;
With the encoders i wan't select the colors of the RGB led strips. One encoder and one switch ( to make color swirl ) vor each strip.
I have problems with making the code. I have a piece of code that works with one encoder and no color swirl.
( The code for 1 rotary encoder );
// RGB bedroom
int redPin = 3;
int greenPin = 5;
int bluePin = 6;
int aPin = 4;
int bPin = 7;
int buttonPin = 2;
boolean isOn = true;
int color = 0;
// color libary
long colors[48]= {
0xFF2000, 0xFF4000, 0xFF6000, 0xFF8000, 0xFFA000, 0xFFC000, 0xFFE000, 0xFFFF00,
0xE0FF00, 0xC0FF00, 0xA0FF00, 0x80FF00, 0x60FF00, 0x40FF00, 0x20FF00, 0x00FF00,
0x00FF20, 0x00FF40, 0x00FF60, 0x00FF80, 0x00FFA0, 0x00FFC0, 0x00FFE0, 0x00FFFF,
0x00E0FF, 0x00C0FF, 0x00A0FF, 0x0080FF, 0x0060FF, 0x0040FF, 0x0020FF, 0x0000FF,
0x2000FF, 0x4000FF, 0x6000FF, 0x8000FF, 0xA000FF, 0xC000FF, 0xE000FF, 0xFF00FF,
0xFF00E0, 0xFF00C0, 0xFF00A0, 0xFF0080, 0xFF0060, 0xFF0040, 0xFF0020, 0xFF0000
pinMode(aPin, INPUT);
pinMode(bPin, INPUT);
pinMode(buttonPin, INPUT);
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
if (digitalRead(buttonPin))
isOn = ! isOn;
delay(200); // de-bounce
if (isOn)
int change = getEncoderTurn();
color = color + change;
if (color < 0)
color = 47;
else if (color > 47)
color = 0;
setColor(colors[color]);
setColor(0);
delay(1);
int getEncoderTurn()
// return -1, 0, or +1
static int oldA = LOW;
static int oldB = LOW;
int result = 0;
int newA = digitalRead(aPin);
int newB = digitalRead(bPin);
if (newA != oldA || newB != oldB)
// something has changed
if (oldA == LOW && newA == HIGH)
result = -(oldB * 2 - 1);
oldA = newA;
oldB = newB;
return result;
void setColor(long rgb)
int red = rgb >> 16;
int green = (rgb >> 8 ) & 0xFF;
int blue = rgb & 0xFF;
analogWrite(redPin, 255 - red);
analogWrite(greenPin, 255 - green);
analogWrite(bluePin, 255 - blue);
My question is to you ( the forrums users ). Would you help me with this code to make it use 2 encoders for 2 strips and 2 buttons for 2 color swirl on the led strips
Any help appreciated. Thanks.
