problem with writing on sd card
Hello, i have problem with sd card writing... I use DS1302 RTC, sd card reader and a light sensor.
I get good light readings on serial monitor, but on sd card i get 4-5 black dots... Also time is displayed like this:
12:00:00
aaaaa
12:00:05
aaaaa
00:00:00
aaaaa
12:00:15
00:00:00
12:00:25
00:00:00
aaaaa
12:00:35
Please help, this is my code:
#include <SD.h>
#include <SPI.h>
#include <DS1302.h>
// Init the DS1302
DS1302 rtc(4, 3, 2);
int CS_PIN = 10;
File file;
const int svetlostPin = A0;
int stanje = 0;
  rtc.halt(false);
  rtc.writeProtect(false);
  // The following lines can be commented out to use the values already stored in the DS1302
  rtc.setDOW(FRIDAY);        // Set Day-of-Week to FRIDAY
  rtc.setTime(12, 0, 0);     // Set the time to 12:00:00 (24hr format)
  rtc.setDate(6, 8, 2010);   // Set the date to August 6th, 2010
  initializeSD();
  stanje = analogRead(svetlostPin);
createFile("svetlost.txt");
writeToFile(rtc.getTimeStr());
writeToFile(analogRead(A0));
closeFile();
Serial.println(stanje);
delay(5000);
void initializeSD()
  Serial.println("Initializing SD card...");
  pinMode(CS_PIN, OUTPUT);
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
int createFile(char filename[])
  file = SD.open(filename, FILE_WRITE);
  if (file)
    Serial.println("Tekst dokument uspesno kreiran");
    return 1;
  } else
    Serial.println("Tekst dokument neuspesno kreiran");
    return 0;
int writeToFile(char text[])
  if (file)
    file.println(text);
    Serial.println("Writing to file: ");
    Serial.println(text);
    return 1;
  } else
    Serial.println("Couldn't write to file");
    return 0;
void closeFile()
  if (file)
    file.close();
    Serial.println("File closed");
int openFile(char filename[])
  file = SD.open(filename);
  if (file)
    Serial.println("File opened with success!");
    return 1;
  } else
    Serial.println("Error opening file...");
    return 0;
String readLine()
  String received = "";
  char ch;
  while (file.available())
    ch = file.read();
    if (ch == '\n')
      return String(received);
      received += ch;
  return "";
aaaaa
you are doing this writeToFile([color=red]analogRead(A0)[/color]);
for a function you defined like this int writeToFile([color=red]char text[][/color])
do you see the pb?
didn't you get an alert when compiling?
Im new to programming.. Pls explain to me what does pb mean? Also i dont understand char text[]..
If i wrote stanje = analogRead(A0), does that mean i should write writeToFile(stanje)? Because i got same thing with that... :slight_smile:
well better start then with a good book or tutorial on the syntax of the language...
trying to explain a bit, consider this code
char myPhrase[] = "Hello World";
int value = 100;
void writePhrase(char text[])
  Serial.print("The text is: '");
  Serial.print(text);
  Serial.println("'");
  writePhrase(myPhrase); // kinda OK  passing indeed an array of characters
  writePhrase(value); // Bad - not passing an array of characters
void loop() {}
if you compile this, you'll see that the compiler is not happy and throws warnings
warning: invalid conversion from 'int' to 'char*' [-fpermissive]
   writePhrase(value);
 note: initializing argument 1 of 'void writePhrase(char*)'
so that tells you your code is not perfect and you need to fix this...
if you run it anyway, you'll see in the console
The text is: 'Hello World'
The text is: ''
so the first phrase worked but clearly it did not work for the second because I passed an integer to a function which was expecting a pointer to a string of character
hope that helps a bit
