Problem with XOR on Char array
I just get crazzy with a bit of code for calculating a simple XOR checksum on a char array to build a message for a serial stream over an xbee. The message has the same format as NEMA message $..*checksum
The checksum is even wrong calculated. I checked it here: cecksum calculator.
The code on the other side for checkin the checksum works fine with the same algorithm!? Hope you have an idea. I extracted the part to a test program to debug it more easy. Only to avoid confusion:
First I have string to build with the message. Only for the checksum test I transfered it to char array.
String MessageStr ="";
bool read = false;
char MessageBuffer[100]="";
	Serial.println("Checksum-Test");
	Serial.println("Enter String to check: ");
	if (Serial.available())
		while (Serial.available())
			MessageStr=Serial.readString();
			read = true;
		if (read)
			Serial.print("String read: ");
			Serial.println(MessageStr);
			BuildMessage();
			read=false;
			Serial.println("Next String: ");
void BuildMessage(void) {
	int MesChecksum=0;
	char buf[12];
	//here i build the message
	/*Generating and parsing message checksum
	starting at the 2. Position to not calculate initial '
Here is the part that checks the checksum without any problem:
boolean TelegramCheckChecksum (char* Message, int MessageLength)
	byte checksumReceived=0, checksum=0;
	for (int x = 1; x < MessageLength; x++)
		if (Message[x] == '*') //Checksum starts with '*'
			checksumReceived = strtol(&Message[x + 1], NULL, 16); //Parsing received checksum... |strtol parsing string to integer
			break; //Exit for and continue with next if
			checksum ^= Message[x]; //XOR the received data...
	if (checksum==checksumReceived)
		return true;
		return false;
I hope somebody has an idea where the failure is.
Regards
Andreas*/
MessageStr.toCharArray(MessageBuffer, MessageStr.length());
//for (int x = 1; x < (sizeof(MessageBuffer)/sizeof(MessageBuffer[0])); x++)
//if (MessageBuffer[x] == '*')
//Serial.println("Hier ist der break");
//break;
//else
//Serial.print(MessageBuffer[x]);
//MesChecksum ^= MessageBuffer[x]; //XOR the Message data...
//Serial.println(x);
int x = 1;
while (MessageBuffer[x]!='*')
	Serial.print(x); Serial.print("  ");
	Serial.print(MessageBuffer[x]); Serial.print("  ");Serial.println(MessageBuffer[x], BIN);
	x++;
MessageStr += MesChecksum;
//for clearing the MessageStr:
for (int x = 0; x < (sizeof(MessageBuffer)/sizeof(MessageBuffer[0])); x++)
	MessageBuffer[x]=0;
MesChecksum=0;
§DISCOURSE_HOISTED_CODE_1§
Regards
Andreas
			read = true;
Why is this in a while loop()?
	////Converting float to string
	//dtostrf(lat, 4,6,buf);
	//MessageStr ="$GPS,";
	//MessageStr =MessageStr + buf+","+laterr + ",";
	//dtostrf(lon, 4,6,buf);
	//MessageStr =MessageStr + buf+"," + lonerr;
	//MessageStr =MessageStr + "," +ground_speed + ","
	//+ ground_course + "," + alt_MSL + ","
	//+ alterr + "*";
How much of this shit was it necessary to post?
	//break;
	//else
Or this?
Bullshit. The second argument is the size of the array, not the size of the useless String.
	int x = 1;
Array indices start at 0.]
So, why don't you call that function? What you implement instead is NOT the same.*/
§DISCOURSE_HOISTED_CODE_2§
Or this?
§DISCOURSE_HOISTED_CODE_3§
§DISCOURSE_HOISTED_CODE_4§
Paul, tone it down a bit, please.
I try to ignore the useless behaviour. Though I wanne answer your questions hoping to get a more helpfull reply:
I started with the index at 1 because I don't wan't to include the leading "$" in the calculation. Maybe you should also read the comments written.
I used exactly the same code als ofor building the XOR "it is commented out. I leads to the same result as the while code. But the while code is more lean.
I read from serial with a while loop because I wanted to first, that the complete message is read, because within the real code I also have all informatio navailable before starting to build the checksum.
Regards
Andreas
Maybe you should reduce the amount of commented-out code (and excess whitespace) before posting.
"lean" and "String" don't belong in the same sketch, in my book.
