Problem working a 0,91'' 128x32 OLED I2C Display
Hello to the community.
First of all I just bought an Arduino Nano v3 from ebay so I'm noob in programming this device.
I managed to succesfully implement a code to a project that is showing temprerature and humidity from DHT22 sensor , time from an DS3231 RTC module and store data to an SDcard module.All this in a serial monitor.
Today I get an 0,91'' 128x32 OLED I2C display so the first thing I did was to run the example from library and it is working properly.
I want know to display this informations from the sensors to that OLED but I could'nt.
The code for displaying sensor values and time in serial port is this:
#include "RTClib.h"
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
File myFile;
RTC_DS3231 rtc;
char cl[32];
#include "DHT.h"
#define DHTPIN 4     // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
   if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    while (1);
  dht.begin();
  Wire.begin();
  rtc.begin();
  rtc.adjust(DateTime(F(__DATE__),F(__TIME__)));
  //rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
if (rtc.lostPower()) {
    Serial.println("RTC lost power, lets set the time!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    //rtc.adjust(DateTime(2019, 9, 11, 12, 40, 0));
// Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
DateTime now = rtc.now();
   sprintf(cl, "%02d/%02d/%02d %02d:%02d:%02d",  now.day(), now.month(), now.year(),now.hour(), now.minute(), now.second());
  //Serial.print(F("Date/Time: "));
  Serial.print(cl);
  float hif = dht.computeHeatIndex(f, h); // Compute heat index in Fahrenheit (the default)
  Serial.print(F(" Humidity: "));
  Serial.print(h);
  Serial.print(F("%  Temp1: "));
  Serial.print(t);
  Serial.print(F("°C "));
  Serial.print("  Temp2(RTC) : ");
  Serial.print(rtc.getTemperature());
  Serial.print("°C");
    if (now.second() == 00 ) {
  myFile = SD.open("test.txt", FILE_WRITE);
  myFile.print(cl);
  myFile.print(" , ");
  myFile.print(h);
  myFile.print(t);
  myFile.println(rtc.getTemperature());
  myFile.close();
    Serial.print("  MicroSD REC ");
The lines I implement to make the display to work is the following :
#include "RTClib.h"
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
File myFile;
RTC_DS3231 rtc;
char cl[32];
#include "DHT.h"
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  display.display();
  delay(2000); // Pause for 2 seconds
  // Clear the buffer
  display.clearDisplay();
    while (1);
  dht.begin();
  Wire.begin();
  rtc.begin();
    while (1);
    return;
  //Serial.print(cl);
  display.setTextSize(1);             // Normal 1:1 pixel scale
  display.setTextColor(WHITE);        // Draw white text
  display.setCursor(0,0);             // Start at top-left corner
  display.print(cl);
  display.print(F(" Humidity: "));
  display.print(h);
  display.print(F("%  Temp1: "));
  display.print(t);
  display.print(F("°C "));
  display.print("  Temp2(RTC) : ");
  display.print(rtc.getTemperature());
  display.print("°C");
  display.display();
  //Serial.print(F(" Humidity: "));
  //Serial.print(h);
  //Serial.print(F("%  Temp1: "));
  //Serial.print(t);
  //Serial.print(F("°C "));
  //Serial.print("  Temp2(RTC) : ");
  //Serial.print(rtc.getTemperature());
  //Serial.print("°C");
  myFile.print(cl);
  myFile.print(h);
  myFile.print(t);
  myFile.close();
The green led in nano is not blinking at all with this code.Can anyone have a clue what I'm doing wrong?
Thanks in advanced.
Does your code compile? Is there any information such as compile or link error?
You should try to remove the character ° from your display.print instructions.
Try uncommenting your Serial.print to follow the execution of the program (if it even executes).
Thanks for the reply.
The code is compiled witout any errors.I removed the special character ° as you told me and I uncommented the serial.print but I do get the same results.No green led blinking.
In the commments it says "Sketch uses 28518 (92%) of program storage space.Minimum is 30720bytes.
Global variables uses 1401byes (68%) of dynamic memory,leaving 647 bytes for local variables.Maximum is 2048 bytes."
I also run a I2C scanner program that found the below addresses :
Address 60 : (0x3C)
Address 87 : (0x57)
Address 104 : (0x68)
Move the Serial.begin at the very beginning of the setup, and try again...
Sorry , my mistake:
I get the message " SSD1306 allocation failed" on serial port
OK, so you have a display problem. As the scanner finds it, it's not a I2C problem. As you have tested it with an example from the library, it's not a display problem stricto sensu.
First double check that you didn't forget some initialization call for the display.
If not, then it may be due to a library compatibility problem between the SSD1306 library and another one (RTC or DHT22).
Choose either the DHT or the RTC, unplug it from your board, comment all the related functions (and the #include) and see if it works better.
I removed the DHT22 sensor and let the RTC and microSD module onboard.I commented the commands related to the DHT22 module and now I have the Adafruit logo displayed permanent on the OLED display and on serial port I get the values from RTC temp sensor.
The display.print command do nothing on the display.It keeps the Adafruit logo all the time.
This is not hapening....I fried the display....It came out smoke! LOL
Maybe because I didn't soldered the pins yet because I have not solder iron.
Is that possible? I'm so frustrated now!
