I am new to arduino, I just got the Arduino Due in October. I am trying to modify SimpleAudioPlayer to play 1.wav when I press a pushbutton attached to digital pin 1 or play 2.wav off an SD card when I press button 2.
Can someone help me fix this problem?
here is the code:
// modded audio player
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
int buttonPin = 2;
int buttonPin2 = 3;
// setup SD-card
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println(" failed!");
return;
Serial.println(" done.");
// hi-speed SPI transfers
SPI.setClockDivider(4);
Serial.print("set pin 1 mode...");
pinMode(buttonPin, INPUT_PULLUP);
Serial.print("Done!");
Serial.println("set pin 2 mode...");
pinMode(buttonPin2, INPUT_PULLUP);
Serial.print(" Done! ");
// 44100Khz stereo => 88200 sample rate
// 256 mSec of prebuffering.
Audio.begin(88200, 256);
Serial.println("audiobegin");
int count = 0;
// open wave file from sdcard
int buttonState = digitalRead(buttonPin) ;
int buttonState2 = digitalRead(buttonPin2) ;
File myFile;
if (buttonState = 1) {
File myFile = SD.open("1.wav"); Serial.println("button 1 on!"); }
if (buttonState2 = 1) {
File myFile = SD.open("2.wav"); Serial.println("button 2 on!"); }
if (buttonState = 0) {Serial.println("button 1 off!"); }
if (buttonState2 = 0) {Serial.println("button 2 off!"); }
if (!myFile) {
// if the file didn't open, print an error and stop
Serial.println("error opening wave file!") ;
while (true);
const int S = 1200 ; // Number of samples to read in block
short buffer[S] ;
Serial.print("Playing");
// until the file is not finished
while (myFile.available()) {
// read from the file into buffer
myFile.read(buffer, sizeof(buffer));
// Prepare samples
int volume = 1024;
Audio.prepare(buffer, S, volume);
// Feed samples to audio
Audio.write(buffer, S);
// Every 100 block print a '.'
count++;
if (count == 100) {
Serial.print(".");
count = 0;
myFile.close();
Serial.println("End of file. Thank you for listening!");
while (true) ;
And if this helps this is what i get from the serial console
pcwizzy16:
No I enabled internal pulldowns and even used external pulldown resistors and it does the same thing.
There ain't such a thing like "internal pulldowns", Atmega controllers have "internal pullups".
OK, you edited your posting and the posted code after I answered.
But you didn't correct the comparison:
The equals sign '=' is an assignment.
You wanted to do most likely a comparison with the double equals '==':
if (buttonState == 1)
If you use both, internal pullups and external pulldowns, most likely the external pulldown will win if it is 10K or less. I'd better not use both at the same time, but EITHER external pulldown OR internal pullup resistors.
