Problem writing the ARDUINO code for digital loadcell weight scale with buzzer
Hello,
I need an ARDUINO programme part made for the buzzer alert. I am a beginner to the coding world. Much appreciate your help.
Project: Making a digital loadcell weight scale with buzzer ( to alert when passing 50g). I have made the load cell scale and now the weight values are displaying. But I need help to program the buzzer alert.
Components needed: Arduino Uno, HX711 board, LCD with I2C, Buzzer
Objective: Please check the attached schematic diagram and the code and write a code to programe the buzzer to alert when the weight is passing 50 g.
Note: code is a mixture of codes I found on the internet combined together to make it work, so it will look confusing. Do not hesitate to erase unnecessary parts and add as necessary.
Note : I only need the buzzer alert part made. other parts i got covered. All the code and schematic diagram credits goes to the original owner.
Thank you very much!
#include <HX711.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
int IN1 = A0;
int IN2 = A1;
int over_val;
int data;
int g_weight;
int Weight;
const int buzzer = 13;
#include <HX711.h>
#define DOUT 3
#define CLK  2
HX711 scale(DOUT, CLK);
float calibration_factor = 2125; //-7050 worked for my 440lb max scale setup
float units;
float ounces;
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
  lcd.setCursor(0, 0);
  lcd.print("HX711 calibration");
  Serial.println("HX711 calibration sketch");
  Serial.println("Remove all weight from scale");
  Serial.println("After readings begin, place known weight on scale");
  Serial.println("Press + or a to increase calibration factor");
  Serial.println("Press - or z to decrease calibration factor");
  scale.set_scale();
  scale.tare();  //Reset the scale to 0
  long zero_factor = scale.read_average(); //Get a baseline reading
  Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
  Serial.println(zero_factor);
  scale.set_scale(calibration_factor); //Adjust to this calibration factor
  Serial.print("Reading: ");
  units = scale.get_units(), 10;
  if (units < 0) {
    units = 0.00;
  ounces = units * 0.035274;
  Serial.print(units);
  Serial.print(" grams");
  Serial.print(" calibration_factor: ");
  Serial.print(calibration_factor);
  lcd.setCursor(0, 1);
  lcd.print("Grams: ");
  lcd.print(units);
  lcd.setCursor(0, 2);
  lcd.print("Ounce: ");
  lcd.print(ounces);
  lcd.setCursor(0, 3);
  lcd.print("Calbr: ");
  lcd.print(calibration_factor);
  if(Serial.available())
    char temp = Serial.read();
    if(temp == '+' || temp == 'a')
      calibration_factor += 1;
    else if(temp == '-' || temp == 'z')
      calibration_factor -= 1;
You need a variable that has the grams.
Are "units" the grams ? Which HX711 library do you use ? There are probably examples with it, that shows where the grams are.
If( grams > 50)
  digitalWrite( buzzerPin, HIGH);
  delay( 1000);
  digitalWrite( buzzerPin, LOW);
What kind of buzzer is it ? Can you give a link to it or show a photo ?
