hola,estoy tratando de usar el SIM800L en un proyecto, puedo recibir y responder los SMS con el
siguente codigo usando la libreria de Adafruit
#include "Adafruit_FONA.h"
#define FONA_RX 11
#define FONA_TX 12
#define FONA_RST 9
// this is a large buffer for replies
char replybuffer[255];
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
while (!Serial);
Serial.println(F("FONA SMS caller ID test"));
Serial.println(F("Initializing....(May take 3 seconds)"));
// make it slow so its easy to read!
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while(1);
Serial.println(F("FONA is OK"));
char fonaInBuffer[64]; //for notifications from the FONA
char* bufPtr = fonaInBuffer; //handy buffer pointer
if (fona.available()) //any data available from the FONA?
int slot = 0; //this will be the slot number of the SMS
int charCount = 0;
//Read the notification into fonaInBuffer
do {
*bufPtr = fona.read();
Serial.write(*bufPtr);
delay(1);
} while ((*bufPtr++ != '\n') && (fona.available()) && (++charCount < (sizeof(fonaInBuffer)-1)));
//Add a terminal NULL to the notification string
*bufPtr = 0;
//Scan the notification string for an SMS received notification.
// If it's an SMS message, we'll get the slot number in 'slot'
if (1 == sscanf(fonaInBuffer, "+CMTI: \"SM\",%d", &slot)) {
Serial.print("slot: "); Serial.println(slot);
char callerIDbuffer[32]; //we'll store the SMS sender number in here
// Retrieve SMS sender address/phone number.
if (! fona.getSMSSender(slot, callerIDbuffer, 31)) {
Serial.println("Didn't find SMS message in slot!");
Serial.print(F("FROM: ")); Serial.println(callerIDbuffer);
uint16_t smslen;
if (! fona.readSMS(slot, replybuffer, 250, &smslen)) { // pass in buffer and max len!
Serial.println("Failed!");
Serial.print(" ("); Serial.print(smslen); Serial.println(F(") bytes *****"));
Serial.println(replybuffer);
Serial.println(F("*****"));
//Send back an automatic response
Serial.println("Respondiendo");
if (!fona.sendSMS(callerIDbuffer, "Me llego tu mensaje!")) {
Serial.println(F("Failed"));
Serial.println(F("Sent!"));
pero necesito borrar los mensajes SMS para asi prevenir que la SIM se llene e impida recibir SMS
escribi el siguiente codigo segun el ejemplo de la libreria pero no funciona
#define FONA_RX 11
#define FONA_TX 12
#define FONA_RST 9
while (!Serial);
while(1);
int charCount = 0;
do {
delay(1);
*bufPtr = 0;
uint16_t smslen;
// flushSerial();
Serial.print(F("Delete #"));
uint8_t smsn = readnumber();
Serial.print(F("\n\rDeleting SMS #")); Serial.println(smsn);
if (fona.deleteSMS(smsn)) {
Serial.println(F("OK!"));
Serial.println(F("Couldn't delete"));
char readBlocking() {
while (!Serial.available());
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print(c);
Serial.print(c);
x = c - '0';
while (isdigit(c = readBlocking())) {
Serial.print(c);
x *= 10;
x += c - '0';
return x;
¿ alguien sabe como podria borrar los sms una vez llegados, leidos y respondidos ?, por anticipado…gracias
