Buenas grupo.
Estoy iniciando en este maravilloso mundo del arduino y al momento de compilar los ejemplos que vienen por default en el programa me sale esto:
Arduino:1.8.5 (Windows 10), Tarjeta:"Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\raulc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\raulc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\raulc\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\raulc\AppData\Local\Temp\arduino_build_142030 -warnings=all -build-cache C:\Users\raulc\AppData\Local\Temp\arduino_cache_453873 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\raulc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\raulc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\raulc\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\raulc\AppData\Local\Temp\arduino_build_142030 -warnings=all -build-cache C:\Users\raulc\AppData\Local\Temp\arduino_cache_453873 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'uno' from platform in folder: C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Using core 'arduino' from platform in folder: C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Detecting libraries used...
"C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030\sketch\Blink.ino.cpp" -o "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilando programa...
"C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\raulc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030\sketch\Blink.ino.cpp" -o "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Users\raulc\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030/Blink.ino.elf" "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030\sketch\Blink.ino.cpp.o" "C:\Users\raulc\AppData\Local\Temp\arduino_build_142030/..\arduino_cache_453873\core\core_arduino_avr_uno_d266f52a16dde2c36b6a5bd15c24329d.a" "-LC:\Users\raulc\AppData\Local\Temp\arduino_build_142030" -lm
c:/users/raulc/appdata/local/arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../lib/gcc/avr/4.9.2/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compilando para la tarjeta Arduino/Genuino Uno.
El programa corria sin broncas pude cargar varios ejemplos yhe ir entendiendo el funcionamiento, apague el equipo de computo, regrese para seguir y empezo a arrojar eso.
Ya probe desinstalar y volver a instalar el software pero sigue igual.
Moderador: Agregado de etiquetas
