problema arduino mega y mpu6050 (SOLUCIONADO)
he probado con el mega, due y uno, version del ide 1.8.2 el codigo a cargar es etste de adafruit mpu6050
// Demo for getting individual unified sensor data from the MPU6050
#include <Adafruit_MPU6050.h>
Adafruit_MPU6050 mpu;
Adafruit_Sensor *mpu_temp, *mpu_accel, *mpu_gyro;
void setup(void) {
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MPU6050 test!");
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
  Serial.println("MPU6050 Found!");
  mpu_temp = mpu.getTemperatureSensor();
  mpu_temp->printSensorDetails();
  mpu_accel = mpu.getAccelerometerSensor();
  mpu_accel->printSensorDetails();
  mpu_gyro = mpu.getGyroSensor();
  mpu_gyro->printSensorDetails();
  //  /* Get a new normalized sensor event */
  sensors_event_t accel;
  sensors_event_t gyro;
  sensors_event_t temp;
  mpu_temp->getEvent(&temp);
  mpu_accel->getEvent(&accel);
  mpu_gyro->getEvent(&gyro);
  Serial.print("\t\tTemperature ");
  Serial.print(temp.temperature);
  Serial.println(" deg C");
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("\t\tAccel X: ");
  Serial.print(accel.acceleration.x);
  Serial.print(" \tY: ");
  Serial.print(accel.acceleration.y);
  Serial.print(" \tZ: ");
  Serial.print(accel.acceleration.z);
  Serial.println(" m/s^2 ");
  /* Display the results (rotation is measured in rad/s) */
  Serial.print("\t\tGyro X: ");
  Serial.print(gyro.gyro.x);
  Serial.print(gyro.gyro.y);
  Serial.print(gyro.gyro.z);
  Serial.println(" radians/s ");
  delay(100);
  /*   serial plotter friendly format
  Serial.print(",");
  Serial.print(","); Serial.print(accel.acceleration.y);
  Serial.print(","); Serial.print(accel.acceleration.z);
  Serial.print(",");
  Serial.print(","); Serial.print(gyro.gyro.y);
  Serial.print(","); Serial.print(gyro.gyro.z);
  delay(10);
y este el error
Arduino:1.8.12 (Windows 10), Tarjeta:"Arduino Uno"
El Sketch usa 11964 bytes (37%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 705 bytes (34%) de la memoria dinámica, dejando 1343 bytes para las variables locales. El máximo es 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
Ha ocurrido un error mientras se enviaba el sketch
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
