Ciao a tutti,
ho un problema con il codice che allego, mi da un errore di 'processCommands' was not declared in this scope, ma non capisco il perchè. Qualcuno potrebbe darmi una mano? Grazie
#define DEBUG_MODE_OFF
#ifdef DEBUG_MODE_OFF
//get it here: http://www.pjrc.com/teensy/td_libs_OneWire.html
#include <OneWire.h>
//get it here: http://jump.to/fleury
#include <i2cmaster.h>
#include <SPI.h>
#endif
// lowest and highest rain sensor readings:
const int sensorMin = 0; // sensor minimum
const int sensorMax = 1024; // sensor maximum
// misc
#define FirmwareName "CloudSensorEvoPlus"
#define FirmwareNumber "0.1"
#define invalid -999
#define CHKSUM0_OFF
// last rain sensor reading
int rainSensorReading = invalid;
float rainSensorReading2 = invalid;
// last cloud sensor reading
float ds18b20_celsius = invalid;
float MLX90614_celsius = invalid;
float delta_celsius = invalid;
float avg_delta_celsius = 21.5;
OneWire ds(10); // DS18B20 on Arduino pin 10
#endif
byte ds18b20_addr[8];
void setup(void)
init_DS18B20();
init_MLX90614();
void init_DS18B20()
// Serial.println("Initializing DS18B20 sensor...");
while( !ds.search(ds18b20_addr))
ds.reset_search();
delay(250);
#endif
void init_MLX90614()
// Serial.println("Initializing MLX90614 sensor...");
i2c_init(); //Initialise the i2c bus
#endif
// PORTC = (1 << PORTC4) | (1 << PORTC5);//enable pullups if you use 5V sensors and don't have external pullups in the circuit
long last = 0;
void loop(void)
long now=millis();
// gather data from sensors once a second
if ((now%1000==0) && (last!=now)) {
last=now; // blocks calling more than once during the same ms
// Cloud sensor ------------------------------------------------------------
// it might be a good idea to add some error checking and force the values to invalid if something is wrong
ds18b20_celsius = read_DS18B20();
MLX90614_celsius = read_MLX90614();
delta_celsius = abs(ds18b20_celsius - MLX90614_celsius);
avg_delta_celsius = ((avg_delta_celsius*299.0) + delta_celsius)/300.0;
#endif
// End cloud sensor
// Rain sensor -------------------------------------------------------------
// read the sensor on analog A0:
int sensorReading = analogRead(A0);
// map the sensor range (four options):
// ex: 'long int map(long int, long int, long int, long int, long int)'
rainSensorReading = map(sensorReading, sensorMin, sensorMax, 0, 3);
rainSensorReading2 = (float)sensorReading/1023.0;
// End rain sensor
processCommands();
float read_DS18B20()
byte i;
byte present = 0;
byte type_s;
byte data[12];
float celsius;
if (OneWire::crc8(ds18b20_addr, 7) != ds18b20_addr[7])
Serial.println("CRC is not valid!");
return -300.0f;
// the first ROM byte indicates which chip
switch (ds18b20_addr[0])
case 0x10: type_s = 1; break;
case 0x28: type_s = 0; break;
case 0x22: type_s = 0; break;
default:
return -301.0f;
ds.reset();
ds.select(ds18b20_addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.write(0xBE); // Read Scratchpad
//read 9 data bytes
for ( i = 0; i < 9; i++)
data[i] = ds.read();
// Convert the data to actual temperature
int16_t raw = (data[1] << 8) | data[0];
if (type_s)
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
return celsius;
float read_MLX90614()
int dev = 0x5A<<1;
int data_low = 0;
int data_high = 0;
int pec = 0;
i2c_start_wait(dev+I2C_WRITE);
i2c_write(0x07);
// read
i2c_rep_start(dev+I2C_READ);
data_low = i2c_readAck(); //Read 1 byte and then send ack
data_high = i2c_readAck(); //Read 1 byte and then send ack
pec = i2c_readNak();
i2c_stop();
//This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
double tempData = 0x0000; // zero out the data
int frac; // data past the decimal point
// This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
tempData = (double)(((data_high & 0x007F) << 8) + data_low);
tempData = (tempData * tempFactor)-0.01;
float celcius = tempData - 273.15;
return celcius;
#endif
