Problema con codigo sobre usbMIDI
Este es mi codigo
#include <Wire.h>
#include <Adafruit_Trellis.h>
#define LED     13 // Pin for heartbeat LED (shows code is working)
#define CHANNEL 1  // MIDI channel number
Adafruit_Trellis trellis;
uint8_t       heart        = 0;  // Heartbeat LED counter
unsigned long prevReadTime = 0L; // Keypad polling timer
uint8_t       mod;
uint8_t       vel;
uint8_t       fxc;
uint8_t       rate;
uint8_t note[] = {
  60, 61, 62, 63,
  56, 57, 58, 59,
  52, 53, 54, 55,
  48, 49, 50, 51
  pinMode(LED, OUTPUT);
  trellis.begin(0x70); // Pass I2C address
#ifdef __AVR__
  // Default Arduino I2C speed is 100 KHz, but the HT16K33 supports
  // 400 KHz.  We can force this for faster read & refresh, but may
  // break compatibility with other I2C devices...so be prepared to
  // comment this out, or save & restore value as needed.
  TWBR = 12;
#endif
  trellis.clear();
  trellis.writeDisplay();
  mod = map(analogRead(0), 0, 1023, 0, 127);
  vel = map(analogRead(1), 0, 1023, 0, 127);
  fxc = map(analogRead(2), 0, 1023, 0, 127);
  rate = map(analogRead(3),0, 1023, 0, 127);
  usbMIDI.sendControlChange(1, mod, CHANNEL);
  usbMIDI.sendControlChange(11, vel, CHANNEL);
  usbMIDI.sendControlChange(12, fxc, CHANNEL);
  usbMIDI.sendControlChange(13, rate, CHANNEL);
  unsigned long t = millis();
  if((t - prevReadTime) >= 20L) { // 20ms = min Trellis poll time
    if(trellis.readSwitches()) {  // Button state change?
      for(uint8_t i=0; i<16; i++) { // For each button...
        if(trellis.justPressed(i)) {
          usbMIDI.sendNoteOn(note[i], 127, CHANNEL);
          trellis.setLED(i);
        } else if(trellis.justReleased(i)) {
          usbMIDI.sendNoteOff(note[i], 0, CHANNEL);
          trellis.clrLED(i);
    uint8_t newModulation = map(analogRead(0), 0, 1023, 0, 127);
    if(mod != newModulation) {
      mod = newModulation;
    uint8_t newVelocity = map(analogRead(1), 0, 1023, 0, 127);
    if(vel != newVelocity) {
      vel = newVelocity;
    uint8_t newEffect = map(analogRead(2), 0, 1023, 0, 127);
    if(fxc != newEffect) {
      fxc = newEffect;
    uint8_t newRate = map(analogRead(3), 0, 1023, 0, 127);
    if(rate !=newRate) {
      rate = newRate;
    prevReadTime = t;
    digitalWrite(LED, ++heart & 32); // Blink = alive
  while(usbMIDI.read()); // Discard incoming MIDI messages
Y estos los errores:
C:\Users\Alumnos\Documents\Arduino\sketch_sep18d\sketch_sep18d.ino: In function 'void setup()':
sketch_sep18d:39:3: error: 'usbMIDI' was not declared in this scope
C:\Users\Alumnos\Documents\Arduino\sketch_sep18d\sketch_sep18d.ino: In function 'void loop()':
sketch_sep18d:52:11: error: 'usbMIDI' was not declared in this scope
sketch_sep18d:56:11: error: 'usbMIDI' was not declared in this scope
sketch_sep18d:65:7: error: 'usbMIDI' was not declared in this scope
sketch_sep18d:70:7: error: 'usbMIDI' was not declared in this scope
sketch_sep18d:75:7: error: 'usbMIDI' was not declared in this scope
sketch_sep18d:80:7: error: 'usbMIDI' was not declared in this scope
sketch_sep18d:85:9: error: 'usbMIDI' was not declared in this scope
exit status 1
