Problema con el código, os necesito
Resulta que estoy creando la mochila de protones de los cazafantasmas. Y no consigo que funcione el código correctamente.
Los códigos los saque de un proyecto encontrado por internet. Cuando intento que me funcione la función del grafico de barras. El circuito deja de funcionar. Y no consigo ver el fallo.
Esta parte del código me funciona:
#include <QueueArray.h>
// for the sound board
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
// for led triggers
#define HIGH 0x1
#define LOW  0x0
// neopixel pins / setup
#define NEO_POWER 2 // for cyclotron and powercell
Adafruit_NeoPixel powerStick = Adafruit_NeoPixel(48, NEO_POWER, NEO_GRB + NEO_KHZ800);
#define NEO_NOSE 3 // for nose of wand
Adafruit_NeoPixel noseJewel = Adafruit_NeoPixel(7, NEO_NOSE, NEO_GRB + NEO_KHZ800);
#define NEO_WAND 4 // for nose of wand
Adafruit_NeoPixel wandLights = Adafruit_NeoPixel(4, NEO_WAND, NEO_GRB + NEO_KHZ800);
// LED indexes into the neopixel powerstick chain for the cyclotron. Each stick has 8 neopixels for a total of
// 16 with an index starting at 0. These offsets are because my powercell window only shows 13 leds. If you can show more
// change the offset index and powercell count to get more or less lit.
const int powercellLedCount = 14;                                         // total number of led's in the animation
const int powercellIndexOffset = 1;                                       // first led offset into the led chain for the animation
// These are the indexes for the led's on the chain. Each jewel has 7 LEDs. If you are using a single neopixel or
// some other neopixel configuration you will need to update these indexes to match where things are in the chain
const int c1Start = 16;
const int c1End = 22;
const int c2Start = 23;
const int c2End = 29;
const int c3Start = 30;
const int c3End = 36;
const int c4Start = 37;
const int c4End = 43;
const int ventStart = 44;
const int ventEnd = 47;
// inputs for switches and buttons
const int THEME_SWITCH = 5;
const int STARTUP_SWITCH = 6;
const int SAFETY_SWITCH = 7;
const int FIRE_BUTTON = 8;
// soundboard pins and setup
#define SFX_RST 9
#define SFX_RX 10
#define SFX_TX 11
const int ACT = 12;    // this allows us to know if the audio is playing
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
Adafruit_Soundboard sfx = Adafruit_Soundboard( &ss, NULL, SFX_RST);
// available options
const bool useGameCyclotronEffect = true;   // set this to true to get the fading previous cyclotron light in the idle sequence
const bool useCyclotronFadeInEffect = false; // Instead of the yellow alternate flashing on boot/vent this fades the cyclotron in from off to red
const bool useDialogTracks = true;          // set to true if you want the dialog tracks to play after firing for 5 seconds
// Possible Pack states
bool powerBooted = false;   // has the pack booted up
bool isFiring = false;      // keeps track of the firing state
bool shouldWarn = false;    // track the warning state for alert audio
bool shuttingDown = false;  // is the pack in the process of shutting down
bool poweredDown = true;    // is the pack powered down
bool venting = false;       // is the pack venting
// physical switch states
bool startup = false;
bool theme = false;
bool safety = false;
bool fire = false;
bool warning = false;
// audio track names on soundboard
char startupTrack[] =   "T00     WAV";
char blastTrack[] =     "T01     WAV";
char endTrack[] =       "T02     WAV";
char idleTrack[] =      "T03     WAV";
char shutdownTrack[] =  "T04     WAV";
char clickTrack[] =     "T05     WAV";
char chargeTrack[] =    "T06     WAV";
char warnTrack[] =      "T07     WAV";
char ventTrack[] =      "T08     WAV";
char texTrack[] =       "T09     WAV";
char choreTrack[] =     "T10     WAV";
char toolsTrack[] =     "T11     WAV";
char listenTrack[] =    "T12     WAV";
char thatTrack[] =      "T13     WAV";
char neutronizedTrack[]="T14     WAV";
char boxTrack[] =       "T15     WAV";
char themeTrack[] =     "T16     OGG";
// this queue holds a shuffled list of dialog tracks we can pull from so we don't
// play the same ones twice
QueueArray <int> dialogQueue;
int numDialog = 7;
// timer trigger times/states
unsigned long firingStateMillis;
const unsigned long firingWarmWaitTime = 5000;  // how long to hold down fire for lights to speed up
const unsigned long firingWarnWaitTime = 10000;  // how long to hold down fire before warning sounds
// Arduino setup function
  // softwareserial at 9600 baud for the audio board
  ss.begin(9600);
  // set act modes for the fx board
  pinMode(ACT, INPUT);
  // configure nose jewel
  noseJewel.begin();
  noseJewel.setBrightness(100);
  noseJewel.show(); // Initialize all pixels to 'off'
  // configure powercell/cyclotron
  powerStick.begin();
  powerStick.setBrightness(75);
  powerStick.show(); // Initialize all pixels to 'off'
  // configure wand lights
  wandLights.begin();
  wandLights.setBrightness(75);
  wandLights.show();
  // set the modes for the switches/buttons
  pinMode(THEME_SWITCH, INPUT);
  digitalWrite(THEME_SWITCH, HIGH);
  pinMode(STARTUP_SWITCH, INPUT);
  digitalWrite(STARTUP_SWITCH, HIGH);
  pinMode(SAFETY_SWITCH, INPUT);
  digitalWrite(SAFETY_SWITCH, HIGH);
  pinMode(FIRE_BUTTON, INPUT);
  digitalWrite(FIRE_BUTTON, HIGH);
/* ************* Audio Board Helper Functions ************* */
// helper function to play a track by name on the audio board
void playAudio( char* trackname, int playing ) {
  // stop track if one is going
  if (playing == 0) {
    sfx.stop();
  // now go play
  if (sfx.playTrack(trackname)) {
    sfx.unpause();
void playDialogTrack( int playing ){
  // if the queue is empty reseed it
  if ( dialogQueue.isEmpty() ){
    for (int i=1; i<=numDialog; i++){
      dialogQueue.enqueue(i);
  switch (dialogQueue.dequeue()){
    case (1):
      playAudio(texTrack, playing);
    case (2):
      playAudio(listenTrack, playing);
    case (3):
      playAudio(choreTrack, playing);
    case (4):
      playAudio(boxTrack, playing);
    case (5):
      playAudio(thatTrack, playing);
    case (6):
      playAudio(neutronizedTrack, playing);
    case (7):
      playAudio(toolsTrack, playing);
    default:
      playAudio(endTrack, playing);
/* ************* Main Loop ************* */
int cyclotronRunningFadeOut = 255;  // we reset this variable every time we change the cyclotron index so the fade effect works
int cyclotronRunningFadeIn = 0;     // we reset this to 0 to fade the cyclotron in from nothing
// intervals that can be adjusted in real time to speed up animations
unsigned long pwr_interval = 60;        // interval at which to cycle lights for the powercell. We update this in the loop to speed up the animation so must be declared here (milliseconds)
unsigned long cyc_interval = 1000;      // interval at which to cycle lights for the cyclotron.
unsigned long cyc_fade_interval = 15;   // fade the inactive cyclotron to light to nothing
unsigned long firing_interval = 40;     // interval at which to cycle firing lights on the bargraph. We update this in the loop to speed up the animation so must be declared here (milliseconds).
  // get the current time
  // find out of the audio board is playing audio
  int playing = digitalRead(ACT);
  // get the current switch states
  int theme_switch = digitalRead(THEME_SWITCH);
  // if the theme switch has recently changed from off to on we
  // should play the full ghostbusters theme song
  if (theme_switch == 1) {
    if (theme == false) {
      playAudio(themeTrack, playing);
      theme = true;
    theme = false;
  int startup_switch = digitalRead(STARTUP_SWITCH);
  int safety_switch = digitalRead(SAFETY_SWITCH);
  int fire_button = digitalRead(FIRE_BUTTON);
  // while the startup switch is set on
  if (startup_switch == 1) {
    // in general we always try to play the idle sound if started
    if (playing == 1 && startup == true) {
      playAudio(idleTrack, playing);
    // choose the right powercell animation sequence for booted/on
    if ( powerBooted == true ) {
      // standard idle power sequence for the pack
      poweredDown = false;
      venting = false;
      setWandLightState(3, 0, 0); //set sloblow red
      setVentLightState(ventStart, ventEnd, 2);
      powerSequenceOne(currentMillis, pwr_interval, cyc_interval, cyc_fade_interval);
      // boot up the pack. powerSequenceBoot will set powerBooted when complete
      powerSequenceBoot(currentMillis);
      setWandLightState(3, 7, currentMillis);   //set sloblow red blinking
    // if we are not started up we should play the startup sound and begin the boot sequence
    if (startup == false) {
      startup = true;
      playAudio(startupTrack, playing);
      // get the current safety switch state
      if (safety_switch == 1 && safety == false) {
        safety = true;
    if( startup == true && safety_switch == 1 ){
      if( venting == false && powerBooted == true ){
        setWandLightState(1, 2, 0);    //  set back light orange
        setWandLightState(2, 1, 0);    //  set body led white
      }else{
        setWandLightState(1, 4, 0);    //  set back light off
        setWandLightState(2, 4, 0);    //  set body led off
      // if the safety switch is set off then we can fire when the button is pressed
      if ( fire_button == 0) {
        // if the button is just pressed we clear all led's to start the firing animations
        if ( isFiring == false ) {
          shutdown_leds();
          isFiring = true;
        // show the firing bargraph sequence
        barGraphSequenceTwo(currentMillis);
        // strobe the nose pixels
        fireStrobe(currentMillis);
        // now powercell/cyclotron/wand lights
        // if this is the first time reset some variables and play the blast track
        if (fire == false) {
          shouldWarn = false;
          fire = true;
          firingStateMillis = millis();
          playAudio(blastTrack, playing);
          // find out what our timing is
          unsigned long diff = (unsigned long)(millis() - firingStateMillis);
          if ( diff > firingWarnWaitTime) { // if we are in the fire warn interval
            pwr_interval = 10;      // speed up the powercell animation
            firing_interval = 20;   // speed up the bar graph animation
            cyc_interval = 50;      // really speed up cyclotron
            cyc_fade_interval = 5;  // speed up the fade of the cyclotron
            if (playing == 1 || shouldWarn == false ) {
              shouldWarn = true;
              playAudio(warnTrack, playing); // play the firing track with the warning
            setWandLightState(0, 8, currentMillis);    // set top light red flashing fast
          } else if ( diff > firingWarmWaitTime) { // if we are in the dialog playing interval
            pwr_interval = 30;      // speed up the powercell animation
            firing_interval = 30;   // speed up the bar graph animation
            cyc_interval = 200;     // speed up cyclotron
            cyc_fade_interval = 10; // speed up the fade of the cyclotron
            if (playing == 1) {
              playAudio(blastTrack, playing); // play the normal blast track
            setWandLightState(0, 6, currentMillis);    // set top light orange flashing
      } else { // if we were firing and are no longer reset the leds
        if ( isFiring == true ) {
          shutdown_leds();
          isFiring = false;
        // and do the standard bargraph sequence
        barGraphSequenceOne(currentMillis);
        if (fire == true) { // if we were firing let's reset the animations and play the correct final firing track
          clearFireStrobe();
          setWandLightState(0, 4, currentMillis);    // set top light off
          pwr_interval = 60;
          fire = false;
          // see if we've been firing long enough to get the dialog or vent sounds
          if ( diff > firingWarnWaitTime) { // if we are past the warning let's vent the pack
            playAudio(ventTrack, playing);
            venting = true;
            clearPowerStrip(); // play the boot animation on the powercell
          } else if ( diff > firingWarmWaitTime) { // if in the dialog time play the dialog in sequence
            if( useDialogTracks == true ){
              playDialogTrack(playing);
            }else{
      // if the safety was just changed play the click track
      if (safety == false) {
        safety = true;
        playAudio(chargeTrack, playing);
      // if the safety is switched off play the click track
      if (safety == true) {
        setWandLightState(2, 4, 0);    // set body off
        safety = false;
        playAudio(clickTrack, playing);
  } else { // if we are powering down
    if( poweredDown == false ){
      if( shuttingDown == false ){
        playAudio(shutdownTrack, playing); // play the pack shutdown track
        shuttingDown = true;
      powerSequenceShutdown(currentMillis);
    }else{
      if (startup == true) { // if started reset the variables
        clearPowerStrip(); // clear all led's
        shutdown_leds();
        startup = false;
        safety = false;
        fire = false;
  delay(1);
/*************** Wand Light Helpers *********************/
unsigned long prevFlashMillis = 0; // last time we changed a powercell light in the idle sequence
bool flashState = false;
const unsigned long wandFastFlashInterval = 100; // interval at which we flash the top led on the wand
const unsigned long wandMediumFlashInterval = 500; // interval at which we flash the top led on the wand
void setWandLightState(int lednum, int state, unsigned long currentMillis){
  switch ( state ) {
    case 0: // set led red
      wandLights.setPixelColor(lednum, wandLights.Color(255, 0, 0));
    case 1: // set led white
      wandLights.setPixelColor(lednum, wandLights.Color(255, 255, 255));
    case 2: // set led orange
      wandLights.setPixelColor(lednum, wandLights.Color(255, 127, 0));
    case 3: // set led blue
      wandLights.setPixelColor(lednum, wandLights.Color(0, 0, 255));
    case 4: // set led off
      wandLights.setPixelColor(lednum, 0);
    case 5: // fast white flashing
      if ((unsigned long)(currentMillis - prevFlashMillis) >= wandFastFlashInterval) {
        prevFlashMillis = currentMillis;
        if( flashState == false ){
          flashState = true;
        }else{
          flashState = false;
    case 6: // slower orange flashing
      if ((unsigned long)(currentMillis - prevFlashMillis) >= wandMediumFlashInterval) {
          flashState = true;
        }else{
          flashState = false;
    case 7: // medium red flashing
          flashState = true;
        }else{
          flashState = false;
    case 8: // fast red flashing
          flashState = true;
        }else{
          flashState = false;
  wandLights.show();
/*************** Vent Light *************************/
void setVentLightState(int startLed, int endLed, int state ){
  switch ( state ) {
    case 0: // set all leds to white
      for(int i=startLed; i <= endLed; i++) {
        powerStick.setPixelColor(i, powerStick.Color(255, 255, 255));
    case 1: // set all leds to blue
        powerStick.setPixelColor(i, powerStick.Color(0, 0, 255));
    case 2: // set all leds off
        powerStick.setPixelColor(i, 0);
/*************** Powercell/Cyclotron Animations *********************/
// timer helpers and intervals for the animations
unsigned long prevPwrBootMillis = 0;    // the last time we changed a powercell light in the boot sequence
const unsigned long pwr_boot_interval = 60;       // interval at which to cycle lights (milliseconds). Adjust this if
unsigned long prevCycBootMillis = 0;    // the last time we changed a cyclotron light in the boot sequence
const unsigned long cyc_boot_interval = 500;      // interval at which to cycle lights (milliseconds).
const unsigned long cyc_boot_alt_interval = 600;      // interval at which to cycle lights (milliseconds).
unsigned long prevShtdMillis = 0;       // last time we changed a light in the idle sequence
const unsigned long pwr_shutdown_interval = 200;  // interval at which to cycle lights (milliseconds).
unsigned long prevPwrMillis = 0;        // last time we changed a powercell light in the idle sequence
unsigned long prevCycMillis = 0;        // last time we changed a cyclotron light in the idle sequence
unsigned long prevFadeCycMillis = 0;    // last time we changed a cyclotron light in the idle sequence
// LED tracking variables
const int powerSeqTotal = powercellLedCount;                              // total number of led's for powercell 0 based
int powerSeqNum = powercellIndexOffset;                                   // current running powercell sequence led
int powerShutdownSeqNum = powercellLedCount - powercellIndexOffset;       // shutdown sequence counts down
// animation level trackers for the boot and shutdown
int currentBootLevel = powercellIndexOffset;                              // current powercell boot level sequence led
int currentLightLevel = powercellLedCount - powercellIndexOffset;         // current powercell boot light sequence led
void setCyclotronLightState(int startLed, int endLed, int state ){
  switch ( state ) {
    case 0: // set all leds to red
        powerStick.setPixelColor(i, powerStick.Color(255, 0, 0));
    case 1: // set all leds to orange
        powerStick.setPixelColor(i, powerStick.Color(255, 106, 0));
    case 3: // fade all leds from red
        if( cyclotronRunningFadeOut >= 0 ){
          powerStick.setPixelColor(i, 255 * cyclotronRunningFadeOut/255, 0, 0);
          cyclotronRunningFadeOut--;
        }else{
    case 4: // fade all leds to red
        if( cyclotronRunningFadeIn < 255 ){
          powerStick.setPixelColor(i, 255 * cyclotronRunningFadeIn/255, 0, 0);
          cyclotronRunningFadeIn++;
        }else{
// shuts off and resets the powercell/cyclotron leds
void clearPowerStrip() {
  // reset vars
  poweredDown = true;
  currentLightLevel = powercellLedCount;
  // shutoff the leds
  for ( int i = 0; i <= c4End; i++) {
  powerStick.show();
  for ( int j=0; j<=3; j++ ){
    wandLights.setPixelColor(j, 0);
  wandLights.show();
  if( venting == true ){
    setVentLightState(ventStart, ventEnd, 0);
// boot animation on the powercell/cyclotron
bool reverseBootCyclotron = false;
void powerSequenceBoot(unsigned long currentMillis) {
  bool doUpdate = false;
  // START CYCLOTRON
  if( useCyclotronFadeInEffect == false ){
    if ((unsigned long)(currentMillis - prevCycBootMillis) >= cyc_boot_interval) {
      prevCycBootMillis = currentMillis;
      if( reverseBootCyclotron == false ){
        setCyclotronLightState(c1Start, c1End, 1);
        setCyclotronLightState(c2Start, c2End, 2);
        setCyclotronLightState(c3Start, c3End, 1);
        setCyclotronLightState(c4Start, c4End, 2);
        doUpdate = true;
        reverseBootCyclotron = true;
      }else{
        setCyclotronLightState(c1Start, c1End, 2);
        setCyclotronLightState(c2Start, c2End, 1);
        setCyclotronLightState(c3Start, c3End, 2);
        setCyclotronLightState(c4Start, c4End, 1);
        doUpdate = true;
  }else{
    if ((unsigned long)(currentMillis - prevCycBootMillis) >= cyc_boot_alt_interval) {
      setCyclotronLightState(c1Start, c4End, 4);
      doUpdate = true;
  // END CYCLOTRON
  if ((unsigned long)(currentMillis - prevPwrBootMillis) >= pwr_boot_interval) {
    // save the last time you blinked the LED
    prevPwrBootMillis = currentMillis;
    // START POWERCELL
    if( currentBootLevel != powerSeqTotal ){
      if( currentBootLevel == currentLightLevel){
        if(currentLightLevel+1 <= powerSeqTotal){
          powerStick.setPixelColor(currentLightLevel+1, 0);
        powerStick.setPixelColor(currentBootLevel, powerStick.Color(0, 0, 255));
        currentLightLevel = powerSeqTotal;
        currentBootLevel++;
      }else{
        powerStick.setPixelColor(currentLightLevel, powerStick.Color(0, 0, 255));
        currentLightLevel--;
      doUpdate = true;
    }else{
      powerBooted = true;
    // END POWERCELL
  // if we have changed an led
  if( doUpdate == true ){
    powerStick.show(); // commit all of the changes
// idle/firing animation for the powercell/cyclotron
int cycOrder = 0;     // which cyclotron led will be lit next
int cycFading = -1;   // which cyclotron led is fading out for game style
void powerSequenceOne(unsigned long currentMillis, unsigned long anispeed, unsigned long cycspeed, unsigned long cycfadespeed) {
  bool doUpdate = false;  // keep track of if we changed something so we only update on changes
  // START CYCLOTRON
  if( useGameCyclotronEffect == true ){ // if we are doing the video game style cyclotron
    if ((unsigned long)(currentMillis - prevCycMillis) >= cycspeed) {
      prevCycMillis = currentMillis;
      switch ( cycOrder ) {
        case 0:
          setCyclotronLightState(c1Start, c1End, 0);
          cycFading = 0;
          cycOrder = 1;
        case 1:
          setCyclotronLightState(c2Start, c2End, 0);
          cycFading = 1;
          cycOrder = 2;
        case 2:
          setCyclotronLightState(c3Start, c3End, 0);
          cycFading = 2;
          cycOrder = 3;
        case 3:
          setCyclotronLightState(c4Start, c4End, 0);
          cycFading = 3;
          cycOrder = 0;
      doUpdate = true;
    // now figure out the fading light
    if( (unsigned long)( currentMillis - prevFadeCycMillis) >= cycfadespeed ){
      prevFadeCycMillis = currentMillis;
      if( cycFading != -1 ){
        switch ( cycFading ) {
          case 0:
            setCyclotronLightState(c4Start, c4End, 3);
          case 1:
            setCyclotronLightState(c1Start, c1End, 3);
          case 2:
            setCyclotronLightState(c2Start, c2End, 3);
          case 3:
            setCyclotronLightState(c3Start, c3End, 3);
        doUpdate = true;
  }else{ // otherwise this is the standard version
        case 0:
          cycFading = 0;
          cycOrder = 1;
        case 1:
          cycFading = 1;
          cycOrder = 2;
        case 2:
          cycFading = 2;
          cycOrder = 3;
        case 3:
          cycFading = 3;
          cycOrder = 0;
      doUpdate = true;
  // END CYCLOTRON
  // START POWERCELL
  if ((unsigned long)(currentMillis - prevPwrMillis) >= anispeed) {
    prevPwrMillis = currentMillis;
    for ( int i = powercellIndexOffset; i <= powerSeqTotal; i++) {
      if ( i <= powerSeqNum ) {
        powerStick.setPixelColor(i, powerStick.Color(0, 0, 150));
    if ( powerSeqNum <= powerSeqTotal) {
      powerSeqNum++;
    doUpdate = true;
  // END POWERCELL
  // if we changed anything update
    powerStick.show();
// shutdown animation for the powercell/cyclotron
int cyclotronFadeOut = 255;
void powerSequenceShutdown(unsigned long currentMillis) {
  if ((unsigned long)(currentMillis - prevShtdMillis) >= pwr_shutdown_interval) {
    prevShtdMillis = currentMillis;
    // START CYCLOTRON
    for(int i=c1Start; i <= c4End; i++) {
      if( cyclotronFadeOut >= 0 ){
        powerStick.setPixelColor(i, 255 * cyclotronFadeOut/255, 0, 0);
        cyclotronFadeOut--;
      }else{
    // END CYCLOTRON
    // START POWERCELL
    for ( int i = powerSeqTotal; i >= powercellIndexOffset; i--) {
      if ( i <= powerShutdownSeqNum ) {
    powerStick.show();
    if ( powerShutdownSeqNum >= powercellIndexOffset) {
      powerShutdownSeqNum--;
      poweredDown = true;
    // END POWERCELL
/*************** Nose Jewel Firing Animations *********************/
unsigned long prevFireMillis = 0;
const unsigned long fire_interval = 50;     // interval at which to cycle lights (milliseconds).
int fireSeqNum = 0;
int fireSeqTotal = 5;
void clearFireStrobe() {
  for ( int i = 0; i < 7; i++) {
    noseJewel.setPixelColor(i, 0);
  noseJewel.show();
  fireSeqNum = 0;
void fireStrobe(unsigned long currentMillis) {
  if ((unsigned long)(currentMillis - prevFireMillis) >= fire_interval) {
    prevFireMillis = currentMillis;
    switch ( fireSeqNum ) {
      case 0:
        noseJewel.setPixelColor(0, noseJewel.Color(255, 255, 255));
        noseJewel.setPixelColor(1, noseJewel.Color(255, 255, 255));
        noseJewel.setPixelColor(2, 0);
        noseJewel.setPixelColor(3, noseJewel.Color(255, 255, 255));
        noseJewel.setPixelColor(4, 0);
        noseJewel.setPixelColor(5, noseJewel.Color(255, 255, 255));
        noseJewel.setPixelColor(6, 0);
      case 1:
        noseJewel.setPixelColor(0, noseJewel.Color(0, 0, 255));
        noseJewel.setPixelColor(1, noseJewel.Color(255, 0, 0));
        noseJewel.setPixelColor(2, noseJewel.Color(255, 255, 255));
        noseJewel.setPixelColor(3, noseJewel.Color(255, 0, 0));
        noseJewel.setPixelColor(4, noseJewel.Color(255, 255, 255));
        noseJewel.setPixelColor(5, noseJewel.Color(255, 0, 0));
        noseJewel.setPixelColor(6, noseJewel.Color(255, 255, 255));
      case 2:
        noseJewel.setPixelColor(0, noseJewel.Color(255, 0, 0));
        noseJewel.setPixelColor(1, 0);
        noseJewel.setPixelColor(2, noseJewel.Color(0, 0, 255));
        noseJewel.setPixelColor(3, 0);
        noseJewel.setPixelColor(4, noseJewel.Color(0, 0, 255));
        noseJewel.setPixelColor(5, 0);
        noseJewel.setPixelColor(6, noseJewel.Color(255, 0, 0));
      case 3:
      case 4:
        noseJewel.setPixelColor(4, noseJewel.Color(255, 0, 0));
      case 5:
        noseJewel.setPixelColor(0, noseJewel.Color(255, 0, 255));
        noseJewel.setPixelColor(1, noseJewel.Color(0, 255, 0));
        noseJewel.setPixelColor(2, noseJewel.Color(255, 0, 0));
        noseJewel.setPixelColor(3, noseJewel.Color(0, 0, 255));
        noseJewel.setPixelColor(4, noseJewel.Color(255, 0, 255));
        noseJewel.setPixelColor(6, noseJewel.Color(0, 0, 255));
    noseJewel.show();
    fireSeqNum++;
    if ( fireSeqNum > fireSeqTotal ) {
      fireSeqNum = 0;
/*************** Bar Graph Animations *********************/
void shutdown_leds() {
  // stub function for when I re-enable to bargraph
void barGraphSequenceOne(unsigned long currentMillis) {
void barGraphSequenceTwo(unsigned long currentMillis) {
Pero cuando intento poner la parte del grafico de barras. Deja de funcionar:
#include <Wire.h> // Include the I2C library (required)
#include <SparkFunSX1509.h> // Include SX1509 library
// for led triggers
#define HIGH 0x1
#define LOW  0x0
// SX1509 I2C address (set by ADDR1 and ADDR0 (00 by default):
const byte SX1509_ADDRESS = 0x3E;  // SX1509 I2C address
SX1509 io; // Create an SX1509 object to be used throughout
// bargraph helper variables
int seq_1_current = 0;  // current led in sequence 1
const int num_led = 15; // total number of leds in bar graph
// SX1509 pin definitions for the leds on the graph:
const byte SX1509_BAR_01 = 0;
const byte SX1509_BAR_02 = 1;
const byte SX1509_BAR_03 = 2;
const byte SX1509_BAR_04 = 3;
const byte SX1509_BAR_05 = 4;
const byte SX1509_BAR_06 = 5;
const byte SX1509_BAR_07 = 6;
const byte SX1509_BAR_08 = 7;
const byte SX1509_BAR_09 = 8;
const byte SX1509_BAR_10 = 9;
const byte SX1509_BAR_11 = 10;
const byte SX1509_BAR_12 = 11;
const byte SX1509_BAR_13 = 12;
const byte SX1509_BAR_14 = 13;
const byte SX1509_BAR_15 = 14;
int c1Start = 16;
int c1End = 22;
int c2Start = 23;
int c2End = 29;
int c3Start = 30;
int c3End = 36;
int c4Start = 37;
int c4End = 43;
int ventStart = 44;
int ventEnd = 47;
#define SFX_RST 9
#define SFX_RX 10
#define SFX_TX 11
bool theme = false;
bool fire = false;
int numDialog = 7;
  ss.begin(9600);
  noseJewel.begin();
  powerStick.begin();
  wandLights.begin();
  wandLights.show();
    // Call io.begin(<address>) to initialize the SX1509. If it
  // successfully communicates, it'll return 1.
  if (!io.begin(SX1509_ADDRESS)) {
    while (1) ; // If we fail to communicate, loop forever for now but it would be nice to warn the user somehow
  // configuration for the bargraph LED's
  io.pinMode(SX1509_BAR_01, OUTPUT);
  io.pinMode(SX1509_BAR_02, OUTPUT);
  io.pinMode(SX1509_BAR_03, OUTPUT);
  io.pinMode(SX1509_BAR_04, OUTPUT);
  io.pinMode(SX1509_BAR_05, OUTPUT);
  io.pinMode(SX1509_BAR_06, OUTPUT);
  io.pinMode(SX1509_BAR_07, OUTPUT);
  io.pinMode(SX1509_BAR_08, OUTPUT);
  io.pinMode(SX1509_BAR_09, OUTPUT);
  io.pinMode(SX1509_BAR_10, OUTPUT);
  io.pinMode(SX1509_BAR_11, OUTPUT);
  io.pinMode(SX1509_BAR_12, OUTPUT);
  io.pinMode(SX1509_BAR_13, OUTPUT);
  io.pinMode(SX1509_BAR_14, OUTPUT);
  io.pinMode(SX1509_BAR_15, OUTPUT);
  // set everything off initially
  shutdown_leds();
  if (playing == 0) {
    sfx.stop();
  // now go play
    sfx.unpause();
    case (1):
    case (2):
    case (3):
    case (4):
    case (5):
    case (6):
    case (7):
    default:
      theme = true;
    theme = false;
      venting = false;
      startup = true;
        safety = true;
      }else{
          shutdown_leds();
          isFiring = true;
          shouldWarn = false;
          fire = true;
              shouldWarn = true;
            if (playing == 1) {
          shutdown_leds();
          isFiring = false;
          clearFireStrobe();
          pwr_interval = 60;
          fire = false;
            venting = true;
            }else{
        safety = true;
        safety = false;
    }else{
        shutdown_leds();
        startup = false;
        safety = false;
        fire = false;
  delay(1);
  switch ( state ) {
          flashState = true;
        }else{
          flashState = false;
          flashState = true;
        }else{
          flashState = false;
          flashState = true;
        }else{
          flashState = false;
          flashState = true;
        }else{
          flashState = false;
  wandLights.show();
  switch ( state ) {
  switch ( state ) {
        }else{
        }else{
  // reset vars
  poweredDown = true;
  // shutoff the leds
  powerStick.show();
  wandLights.show();
  // START CYCLOTRON
        doUpdate = true;
      }else{
        doUpdate = true;
  }else{
      doUpdate = true;
  // END CYCLOTRON
    // START POWERCELL
        currentBootLevel++;
      }else{
      doUpdate = true;
    }else{
      powerBooted = true;
    // END POWERCELL
  // START CYCLOTRON
        case 0:
          cycFading = 0;
          cycOrder = 1;
        case 1:
          cycFading = 1;
          cycOrder = 2;
        case 2:
          cycFading = 2;
          cycOrder = 3;
        case 3:
          cycFading = 3;
          cycOrder = 0;
      doUpdate = true;
          case 0:
          case 1:
          case 2:
          case 3:
        doUpdate = true;
        case 0:
          cycFading = 0;
          cycOrder = 1;
        case 1:
          cycFading = 1;
          cycOrder = 2;
        case 2:
          cycFading = 2;
          cycOrder = 3;
        case 3:
          cycFading = 3;
          cycOrder = 0;
      doUpdate = true;
  // END CYCLOTRON
  // START POWERCELL
      powerSeqNum++;
    doUpdate = true;
  // END POWERCELL
    powerStick.show();
    // START CYCLOTRON
        cyclotronFadeOut--;
      }else{
    // END CYCLOTRON
    // START POWERCELL
    powerStick.show();
      poweredDown = true;
    // END POWERCELL
int fireSeqNum = 0;
  noseJewel.show();
  fireSeqNum = 0;
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
    noseJewel.show();
    fireSeqNum++;
      fireSeqNum = 0;
// This is the idle sequence
unsigned long prevBarMillis_on = 0;          // bargraph on tracker
const unsigned long pwrcl_interval = 60;     // interval at which to cycle lights (milliseconds).
bool reverseSequenceOne = false;
  // normal sync animation on the bar graph
  if ((unsigned long)(currentMillis - prevBarMillis_on) > pwrcl_interval) {
    prevBarMillis_on = currentMillis;
    if ( reverseSequenceOne == false ) {
      switch_graph_led(seq_1_current, HIGH);
      seq_1_current++;
      if ( seq_1_current > num_led ) {
        reverseSequenceOne = true;
      switch_graph_led(seq_1_current, LOW);
      seq_1_current--;
      if ( seq_1_current < 0  ) {
// This is the firing sequence
unsigned long prevBarMillis_fire = 0; // bargraph firing tracker
int fireSequenceNum = 1;
  if ((unsigned long)(currentMillis - prevBarMillis_fire) > firing_interval) {
    prevBarMillis_fire = currentMillis;
    switch (fireSequenceNum) {
      case 1:
        switch_graph_led(2, LOW);
        switch_graph_led(14, LOW);
        switch_graph_led(1, HIGH);
        switch_graph_led(15, HIGH);
        fireSequenceNum++;
      case 2:
        switch_graph_led(1, LOW);
        switch_graph_led(15, LOW);
        switch_graph_led(2, HIGH);
        switch_graph_led(14, HIGH);
        fireSequenceNum++;
      case 3:
        switch_graph_led(3, HIGH);
        switch_graph_led(13, HIGH);
        fireSequenceNum++;
      case 4:
        switch_graph_led(3, LOW);
        switch_graph_led(13, LOW);
        switch_graph_led(4, HIGH);
        switch_graph_led(12, HIGH);
        fireSequenceNum++;
      case 5:
        switch_graph_led(4, LOW);
        switch_graph_led(12, LOW);
        switch_graph_led(5, HIGH);
        switch_graph_led(11, HIGH);
        fireSequenceNum++;
      case 6:
        switch_graph_led(5, LOW);
        switch_graph_led(11, LOW);
        switch_graph_led(6, HIGH);
        switch_graph_led(10, HIGH);
        fireSequenceNum++;
      case 7:
        switch_graph_led(6, LOW);
        switch_graph_led(10, LOW);
        switch_graph_led(7, HIGH);
        switch_graph_led(9, HIGH);
        fireSequenceNum++;
      case 8:
        switch_graph_led(7, LOW);
        switch_graph_led(9, LOW);
        fireSequenceNum++;
      case 9:
        fireSequenceNum++;
      case 10:
        fireSequenceNum++;
      case 11:
        fireSequenceNum++;
      case 12:
/************************* Shutdown and helper functions ****************************/
  // reset the sequence
  seq_1_current = 1;
  // shut all led's off
  for (int i = 1; i <= 15; i++) {
    switch_graph_led(i, LOW);
void switch_graph_led(int num, int state) {
  switch (num) {
    case 1:
      io.digitalWrite(SX1509_BAR_01, state);
    case 2:
      io.digitalWrite(SX1509_BAR_02, state);
    case 3:
      io.digitalWrite(SX1509_BAR_03, state);
    case 4:
      io.digitalWrite(SX1509_BAR_04, state);
    case 5:
      io.digitalWrite(SX1509_BAR_05, state);
    case 6:
      io.digitalWrite(SX1509_BAR_06, state);
    case 7:
      io.digitalWrite(SX1509_BAR_07, state);
    case 8:
      io.digitalWrite(SX1509_BAR_08, state);
    case 9:
      io.digitalWrite(SX1509_BAR_09, state);
    case 10:
      io.digitalWrite(SX1509_BAR_10, state);
    case 11:
      io.digitalWrite(SX1509_BAR_11, state);
    case 12:
      io.digitalWrite(SX1509_BAR_12, state);
    case 13:
      io.digitalWrite(SX1509_BAR_13, state);
    case 14:
      io.digitalWrite(SX1509_BAR_14, state);
    case 15:
      io.digitalWrite(SX1509_BAR_15, state);
Este es el esquema de lo que intento hacer:
:worried: AYUDA POR FAVOR
