Problema con esempio UdpNtpClient
Salve a tutti, da qualche tempo sto cercando di ottenere la data e l’ora da un server Ntp. Sul web viene proposto un po’ ovunque come sketch per risolvere tutti i problemi l’esempio UdpNtpClient della libreria Ethernet, ma a me il codice non produce alcun output sulla mia seriale. Sono in possesso di un arduino clone, come ethernet shield una w5100 e utilizzo l’ide 1.8.5 .
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
unsigned int localPort = 8888;       // local port to listen for UDP packets
char timeServer[] = "time.nist.gov"; // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start Ethernet and UDP
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for (;;)
  Udp.begin(localPort);
  sendNTPpacket(timeServer); // send an NTP packet to a time server
  // wait to see if a reply is available
  if (Udp.parsePacket()) {
    // We've received a packet, read the data from it
    Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
    // the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, extract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    Serial.print("Seconds since Jan 1 1900 = ");
    Serial.println(secsSince1900);
    // now convert NTP time into everyday time:
    Serial.print("Unix time = ");
    // Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
    const unsigned long seventyYears = 2208988800UL;
    // subtract seventy years:
    unsigned long epoch = secsSince1900 - seventyYears;
    // print Unix time:
    Serial.println(epoch);
    // print the hour, minute and second:
    Serial.print("The UTC time is ");       // UTC is the time at Greenwich Meridian (GMT)
    Serial.print((epoch  % 86400L) / 3600); // print the hour (86400 equals secs per day)
    Serial.print(':');
    if (((epoch % 3600) / 60) < 10) {
      // In the first 10 minutes of each hour, we'll want a leading '0'
      Serial.print('0');
    Serial.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
    Serial.print(':');
    if ((epoch % 60) < 10) {
      // In the first 10 seconds of each minute, we'll want a leading '0'
      Serial.print('0');
    Serial.println(epoch % 60); // print the second
  // wait ten seconds before asking for the time again
  delay(10000);
  Ethernet.maintain();
// send an NTP request to the time server at the given address
void sendNTPpacket(char* address) {
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  Udp.endPacket();
Tengo anche a precisare che la shield è perfettamente funzionante, dato che la utilizzo anche per altri progetti.
Buonasera,
essendo il tuo primo post, nel rispetto del regolamento (… punto 13, primo capoverso), ti chiedo cortesemente di presentarti IN QUESTO THREAD (spiegando bene quali conoscenze hai di elettronica e di programmazione ... possibilmente evitando di scrivere solo una riga di saluto) e di leggere con MOLTA attenzione il su citato REGOLAMENTO ... Grazie.
Guglielmo
P.S.: Qui una serie di link utili, NON necessariamente inerenti alla tua domanda:
- serie di schede by xxxPighi per i collegamenti elettronici vari: ABC - Arduino Basic Connections
- pinout delle varie schede by xxxPighi: Pinout
- link generali utili: Link Utili
Prova a cambiare server
io ad esempio uso
IPAddress timeServer(217, 147, 223, 78); //europe.pool.ntp.org
Niente da fare, non mi funziona. L'ethernet shield è montata su un arduino mega, ma non penso che sia dovuto a questo il problema.
Lo shield ethernet che usi è una shield originale ? Hai un link a detta shield ?
Guglielmo
Questo è il link da dove l'ho acquistata: https://it.aliexpress.com/item/Free-Shipping-1pcs-UNO-Shield-Ethernet-Shield-W5100-R3-UNO-Mega-2560-1280-328-UNR-R3/32549379444.html?spm=a2g0s.9042311.0.0.F0bAgU
... mmm .. ok, clone cinese, ma almeno il connettore ISP c'è (sulla MEGA quel connettore viene usato per accedere al bus SPI dato che NON è sugli stessi pin della UNO); verifica che sia ben inserito e faccia ben contatto.
Se fai il ping della scheda ti risponde ? Se carichi altri esempi della libreria Ethernet funzionano (così escludiamo guasti alla scheda) ?
Guglielmo
Sisi tutto ok, la scheda mi risponde, è perfettamente funzionante. Io la utilizzo per la mia stazione meteo, preleva i dati dai sensori e li invia ad un database Mysql. Ora avrei bisogno che la scheda fosse in grado di sapere l'orario, per resettare alla mezzanotte tutti gli estremi della giornata( temperatura massima, minima, umidita massima, minima, ecc..), ma con qualsiasi esempio trovato in rete non vuole saperne di darmi alcun dato in seriale.
Allora ... debbo darti una brutta notizia ...
... ho appena provato sulla mia MEGA con l'Ethernet Shield ORIGINALE Arduino ed il tuo programma funziona perfettamente :
Seconds since Jan 1 1900 = 3721897885
Unix time = 1512909085
The UTC time is 12:31:25
Seconds since Jan 1 1900 = 3721897896
Unix time = 1512909096
The UTC time is 12:31:36
Seconds since Jan 1 1900 = 3721897907
Unix time = 1512909107
The UTC time is 12:31:47
Seconds since Jan 1 1900 = 3721897918
Unix time = 1512909118
The UTC time is 12:31:58
Seconds since Jan 1 1900 = 3721897930
Unix time = 1512909130
The UTC time is 12:32:10
Seconds since Jan 1 1900 = 3721897941
Unix time = 1512909141
The UTC time is 12:32:21
... quindi, c'è qualche problema li da te o nel tuo router che non fa uscire le richieste NTP (ma non ne vedo il motivo) o la tua scheda Ethernet ha dei problemi.
Del resto, se una Arduino Ethernet costa circa 40€ + IVA e quella che hai preso tu costa 6€ ... qualche differenza ci sarà non credi? ::slight_smile:
Guglielmo
