Problema con la programmazione di ESP32
ho comprato un'ESP 32 dev module e quando carico il codice mi dice questo *In file included from c:\users\ultra\onedrive\documenti\arduino\libraries\lvgl\src/lv_init.h:16,
from c:\users\ultra\onedrive\documenti\arduino\libraries\lvgl\lvgl.h:21,
from c:\Users\ultra\OneDrive\Documenti\Arduino\libraries\lvgl\src/lvgl.h:16,
from C:\Users\ultra\Downloads\bombmanjack\bombmanjack.ino:14:
c:\users\ultra\onedrive\documenti\arduino\libraries\lvgl\src/lv_conf_internal.h:60:18: fatal error: ../../lv_conf.h: No such file or directory
60 | #include "../../lv_conf.h" /Else assume lv_conf.h is next to the lvgl folder/
compilation terminated.
exit status 1
Compilation error: exit status 1* aiutatemiiiiii
CHE codice ???
Guglielmo
non ho capito come fare ma eccolo in raw https://raw.githubusercontent.com/RuiSantosdotme/ESP32-TFT-Touchscreen/main/examples/ESP32_LVGL_DS18B20_Temperature/ESP32_LVGL_DS18B20_Temperature.ino
/*  Rui Santos & Sara Santos - Random Nerd Tutorials
    CYD Project Details: https://RandomNerdTutorials.com/esp32-cyd-lvgl-temperature-ds18b20/
    TFT Project Details: https://RandomNerdTutorials.com/esp32-lvgl-ds18b20-tempreature-tft-display/
    THIS EXAMPLE WAS TESTED WITH THE FOLLOWING HARDWARE:
    1) ESP32-2432S028R 2.8 inch 240×320 also known as the Cheap Yellow Display (CYD): https://makeradvisor.com/tools/cyd-cheap-yellow-display-esp32-2432s028r/
      SET UP INSTRUCTIONS: https://RandomNerdTutorials.com/cyd-lvgl/
    2) REGULAR ESP32 Dev Board + 2.8 inch 240x320 TFT Display: https://makeradvisor.com/tools/2-8-inch-ili9341-tft-240x320/ and https://makeradvisor.com/tools/esp32-dev-board-wi-fi-bluetooth/
      SET UP INSTRUCTIONS: https://RandomNerdTutorials.com/esp32-tft-lvgl/
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files. The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
//  *** YOU MUST USE THE lv_conf.h AND User_Setup.h FILES PROVIDED IN THE NEXT LINKS IN ORDER TO USE THE EXAMPLES FROM RANDOM NERD TUTORIALS: https://RandomNerdTutorials.com/cyd-lvgl/ or https://RandomNerdTutorials.com/esp32-tft-lvgl/
//  Install the "lvgl" library version 9.2 by kisvegabor to interface with the TFT Display - https://lvgl.io/ - IMPORTANT: lv_conf.h available on the internet will probably NOT work with the examples available at Random Nerd Tutorials
#include <lvgl.h>
//  Install the "TFT_eSPI" library by Bodmer to interface with the TFT Display - https://github.com/Bodmer/TFT_eSPI - IMPORTANT: User_Setup.h available on the internet will probably NOT work with the examples available at Random Nerd Tutorials
#include <TFT_eSPI.h>
// Install OneWire and DallasTemperature libraries
#include <OneWire.h>
#include <DallasTemperature.h>
// GPIO where the DS18B20 is connected to
const int oneWireBus = 27;
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(oneWireBus);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
// SET VARIABLE TO 0 FOR TEMPERATURE IN FAHRENHEIT DEGREES
#define TEMP_CELSIUS 1
#if TEMP_CELSIUS
  #define TEMP_ARC_MIN -20
  #define TEMP_ARC_MAX 40
#else
  #define TEMP_ARC_MIN -4
  #define TEMP_ARC_MAX 104
#endif
#define SCREEN_WIDTH 240
#define SCREEN_HEIGHT 320
#define DRAW_BUF_SIZE (SCREEN_WIDTH * SCREEN_HEIGHT / 10 * (LV_COLOR_DEPTH / 8))
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
// If logging is enabled, it will inform the user about what is happening in the library
void log_print(lv_log_level_t level, const char * buf) {
  LV_UNUSED(level);
  Serial.println(buf);
  Serial.flush();
lv_obj_t * arc;
// Set the temperature value in the arc and text label
static void set_temp(void * text_label_temp_value, int32_t v) {
  sensors.requestTemperatures();
  // Get the latest temperature reading in Celsius or Fahrenheit
  #if TEMP_CELSIUS
    float ds18b20_temp = sensors.getTempCByIndex(0);
    if(ds18b20_temp <= 10.0) {
      lv_obj_set_style_text_color((lv_obj_t*) text_label_temp_value, lv_palette_main(LV_PALETTE_BLUE), 0);
    else if (ds18b20_temp > 10.0 && ds18b20_temp <= 29.0) {
      lv_obj_set_style_text_color((lv_obj_t*) text_label_temp_value, lv_palette_main(LV_PALETTE_GREEN), 0);
    else {
      lv_obj_set_style_text_color((lv_obj_t*) text_label_temp_value, lv_palette_main(LV_PALETTE_RED), 0);
    const char degree_symbol[] = "\u00B0C";
  #else
    float ds18b20_temp = sensors.getTempFByIndex(0);
    if(ds18b20_temp <= 50.0) {
    else if (ds18b20_temp > 50.0 && ds18b20_temp <= 84.2) {
    else {
    const char degree_symbol[] = "\u00B0F";
  #endif
  lv_arc_set_value(arc, map(int(ds18b20_temp), TEMP_ARC_MIN, TEMP_ARC_MAX, 0, 100));
  String ds18b20_temp_text = String(ds18b20_temp) + degree_symbol;
  lv_label_set_text((lv_obj_t*) text_label_temp_value, ds18b20_temp_text.c_str());
  Serial.print("Temperature: ");
  Serial.println(ds18b20_temp_text);
void lv_create_main_gui(void) {
  // Create an Arc
  arc = lv_arc_create(lv_screen_active());
  lv_obj_set_size(arc, 210, 210);
  lv_arc_set_rotation(arc, 135);
  lv_arc_set_bg_angles(arc, 0, 270);
  lv_obj_set_style_arc_color(arc, lv_color_hex(0x666666), LV_PART_INDICATOR);
  lv_obj_set_style_bg_color(arc, lv_color_hex(0x333333), LV_PART_KNOB);
  lv_obj_align(arc, LV_ALIGN_CENTER, 0, 10);
  // Create a text label in font size 32 to display the latest temperature reading
  lv_obj_t * text_label_temp_value = lv_label_create(lv_screen_active());
  lv_label_set_text(text_label_temp_value, "--.--");
  lv_obj_align(text_label_temp_value, LV_ALIGN_CENTER, 0, 10);
  static lv_style_t style_temp;
  lv_style_init(&style_temp);
  lv_style_set_text_font(&style_temp, &lv_font_montserrat_32);
  lv_obj_add_style(text_label_temp_value, &style_temp, 0);
  // Create an animation to update with the latest temperature value every 10 seconds
  lv_anim_t a_temp;
  lv_anim_init(&a_temp);
  lv_anim_set_exec_cb(&a_temp, set_temp);
  lv_anim_set_duration(&a_temp, 1000000);
  lv_anim_set_playback_duration(&a_temp, 1000000);
  lv_anim_set_var(&a_temp, text_label_temp_value);
  lv_anim_set_values(&a_temp, 0, 100);
  lv_anim_set_repeat_count(&a_temp, LV_ANIM_REPEAT_INFINITE);
  lv_anim_start(&a_temp);
  String LVGL_Arduino = String("LVGL Library Version: ") + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
  Serial.println(LVGL_Arduino);
  // Start the DS18B20 sensor
  sensors.begin();
  // Start LVGL
  lv_init();
  // Register print function for debugging
  lv_log_register_print_cb(log_print);
  // Create a display object
  lv_display_t * disp;
  // Initialize the TFT display using the TFT_eSPI library
  disp = lv_tft_espi_create(SCREEN_WIDTH, SCREEN_HEIGHT, draw_buf, sizeof(draw_buf));
  lv_display_set_rotation(disp, LV_DISPLAY_ROTATION_270);
  // Function to draw the GUI
  lv_create_main_gui();
  lv_task_handler();  // let the GUI do its work
  lv_tick_inc(5);     // tell LVGL how much time has passed
  delay(5);           // let this time pass
Ma tu hai una "ESP32 Cheap Yellow Display Board – CYD" ? Perché quel codice è fatto per quella scheda ... :roll_eyes:
Guglielmo
grazie per aver risolto il mio problema ma volevo chiederti se i codici per arduino uno siano anche per ESP32 (dev module), ho provato a caricare l'esempio del blink e mi dice:
C:\Users\ultra\AppData\Local\Temp.arduinoIDE-unsaved20241126-12160-ti63ax.2ro5\Blink\Blink.ino: In function 'void setup()':
C:\Users\ultra\AppData\Local\Temp.arduinoIDE-unsaved20241126-12160-ti63ax.2ro5\Blink\Blink.ino:28:11: error: 'LED_BUILTIN' was not declared in this scope
28 | pinMode(LED_BUILTIN, OUTPUT);
C:\Users\ultra\AppData\Local\Temp.arduinoIDE-unsaved20241126-12160-ti63ax.2ro5\Blink\Blink.ino: In function 'void loop()':
C:\Users\ultra\AppData\Local\Temp.arduinoIDE-unsaved20241126-12160-ti63ax.2ro5\Blink\Blink.ino:33:16: error: 'LED_BUILTIN' was not declared in this scope
33 | digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
exit status 1
Compilation error: 'LED_BUILTIN' was not declared in this scope
LED_BUILTIN è una definizione che NON fa parte del "framework" Arduino di base, ma normalmente trova posto nelle varie "variant" specifiche per ogni scheda (anche perché, in funzione della scheda, il LED potrebbe essere su un pin piuttosto che su un altro).
Ora, NON tutti i "core" Arduino per le varie schede definiscono LED_BUILTIN e quindi ti da quell'errore.
Se sai su che GPIO è il LED puoi benissimo, in testa al programma aggiungere TU la definizione in modo che poi la riconosca ...
Ad esempio, se il LED è su GPIO2 metti questo in testa al programma:
#ifndef LED_BUILTIN
#define LED_BUILTIN 2
#endif
Guglielmo
