Problema con LCD e libreria MenuBackend
Salve a tutti, stavo testando il mio lcd e volevo implementare un menù nel mio programma, quindi mi ero imbattuto in un tutorial nel web e ho scaricato la libreria e incollato il codice che sotto vi posto: Però mi da un problema , questo :
sketch_oct06b.ino: In function ‘void toRoot()’:
sketch_oct06b:66: error: ‘getRoot’ was not declared in this scope
sketch_oct06b:66: error: ‘setCurrent’ was not declared in this scope
sketch_oct06b.ino: In function ‘void setup()’:
sketch_oct06b:83: error: ‘class MenuBackend’ has no member named ‘toRoot’
sketch_oct06b.ino: In function ‘void menuUsed(MenuUseEvent)’:
sketch_oct06b:134: error: ‘class MenuBackend’ has no member named ‘toRoot’
sketch_oct06b.ino: In function ‘void navigateMenus()’:
sketch_oct06b:278: error: ‘class MenuBackend’ has no member named ‘toRoot’
Non è che sia problema di libreria?
Posto il codice :
Copyright Giuseppe Di Cillo (www.coagula.org)
Contact: dicillo@coagula.org
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
IMPORTANT: to use the menubackend library by Alexander Brevig download it at http://www.arduino.cc/playground/uploads/Profiles/MenuBackend_1-4.zip and add the next code at line 195
void toRoot() {
setCurrent( &getRoot() );
#include <MenuBackend.h> //MenuBackend library - copyright by Alexander Brevig
#include <LiquidCrystal.h> //this library is included in the Arduino IDE
const int buttonPinLeft = 0; // pin for the Up button
const int buttonPinRight = 8; // pin for the Down button
const int buttonPinEsc = 10; // pin for the Esc button
const int buttonPinEnter = 13; // pin for the Enter button
int lastButtonPushed = 0;
int lastButtonEnterState = LOW; // the previous reading from the Enter input pin
int lastButtonEscState = LOW; // the previous reading from the Esc input pin
int lastButtonLeftState = LOW; // the previous reading from the Left input pin
int lastButtonRightState = LOW; // the previous reading from the Right input pin
long lastEnterDebounceTime = 0; // the last time the output pin was toggled
long lastEscDebounceTime = 0; // the last time the output pin was toggled
long lastLeftDebounceTime = 0; // the last time the output pin was toggled
long lastRightDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 500; // the debounce time
// LiquidCrystal display with:
// rs on pin 7
// rw on ground
// enable on pin 6
// d4, d5, d6, d7 on pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//Menu variables
MenuBackend menu = MenuBackend(menuUsed,menuChanged);
//initialize menuitems
MenuItem menu1Item1 = MenuItem(“Item1”);
MenuItem menuItem1SubItem1 = MenuItem(“Item1SubItem1”);
MenuItem menuItem1SubItem2 = MenuItem(“Item1SubItem2”);
MenuItem menu1Item2 = MenuItem(“Item2”);
MenuItem menuItem2SubItem1 = MenuItem(“Item2SubItem1”);
MenuItem menuItem2SubItem2 = MenuItem(“Item2SubItem2”);
MenuItem menuItem3SubItem3 = MenuItem(“Item2SubItem3”);
MenuItem menu1Item3 = MenuItem(“Item3”);
void toRoot() {
pinMode(buttonPinLeft, INPUT);
pinMode(buttonPinRight, INPUT);
pinMode(buttonPinEnter, INPUT);
pinMode(buttonPinEsc, INPUT);
lcd.begin(16, 2);
//configure menu
menu.getRoot().add(menu1Item1);
menu1Item1.addRight(menu1Item2).addRight(menu1Item3);
menu1Item1.add(menuItem1SubItem1).addRight(menuItem1SubItem2);
menu1Item2.add(menuItem2SubItem1).addRight(menuItem2SubItem2).addRight(menuItem3SubItem3);
menu.toRoot();
lcd.setCursor(0,0);
lcd.print(“www.coagula.org”);
} // setup()…
readButtons(); //I splitted button reading and navigation in two procedures because
navigateMenus(); //in some situations I want to use the button for other purpose (eg. to change some settings)
} //loop()…
void menuChanged(MenuChangeEvent changed){
MenuItem newMenuItem=changed.to; //get the destination menu
lcd.setCursor(0,1); //set the start position for lcd printing to the second row
if(newMenuItem.getName()==menu.getRoot()){ lcd.print("Main Menu "); }else if(newMenuItem.getName()=="Item1"){ lcd.print("Item1 "); }else if(newMenuItem.getName()=="Item1SubItem1"){ lcd.print("Item1SubItem1"); }else if(newMenuItem.getName()=="Item1SubItem2"){ lcd.print("Item1SubItem2 "); }else if(newMenuItem.getName()=="Item2"){ lcd.print("Item2 "); }else if(newMenuItem.getName()=="Item2SubItem1"){ lcd.print("Item2SubItem1 "); }else if(newMenuItem.getName()=="Item2SubItem2"){ lcd.print("Item2SubItem2 "); }else if(newMenuItem.getName()=="Item2SubItem3"){ lcd.print("Item2SubItem3 "); }else if(newMenuItem.getName()=="Item3"){ lcd.print("Item3 "); } }
void menuUsed(MenuUseEvent used){ lcd.setCursor(0,0); lcd.print("You used "); lcd.setCursor(0,1); lcd.print(used.item.getName()); delay(3000); //delay to allow message reading lcd.setCursor(0,0); lcd.print("www.coagula.org"); menu.toRoot(); //back to Main }
void readButtons(){ //read buttons status int reading; int buttonEnterState=LOW; // the current reading from the Enter input pin int buttonEscState=LOW; // the current reading from the input pin int buttonLeftState=LOW; // the current reading from the input pin int buttonRightState=LOW; // the current reading from the input pin
//Enter button // read the state of the switch into a local variable: reading = digitalRead(buttonPinEnter);
// check to see if you just pressed the enter button // (i.e. the input went from LOW to HIGH), and you've waited // long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing: if (reading != lastButtonEnterState) { // reset the debouncing timer lastEnterDebounceTime = millis(); }
if ((millis() - lastEnterDebounceTime) > debounceDelay) { // whatever the reading is at, it's been there for longer // than the debounce delay, so take it as the actual current state: buttonEnterState=reading; lastEnterDebounceTime=millis(); }
// save the reading. Next time through the loop, // it'll be the lastButtonState: lastButtonEnterState = reading;
//Esc button // read the state of the switch into a local variable: reading = digitalRead(buttonPinEsc);
// check to see if you just pressed the Down button // (i.e. the input went from LOW to HIGH), and you've waited // long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing: if (reading != lastButtonEscState) { // reset the debouncing timer lastEscDebounceTime = millis(); }
if ((millis() - lastEscDebounceTime) > debounceDelay) { // whatever the reading is at, it's been there for longer // than the debounce delay, so take it as the actual current state: buttonEscState = reading; lastEscDebounceTime=millis(); }
// save the reading. Next time through the loop, // it'll be the lastButtonState: lastButtonEscState = reading;
//Down button // read the state of the switch into a local variable: reading = digitalRead(buttonPinRight);
// If the switch changed, due to noise or pressing: if (reading != lastButtonRightState) { // reset the debouncing timer lastRightDebounceTime = millis(); }
if ((millis() - lastRightDebounceTime) > debounceDelay) { // whatever the reading is at, it's been there for longer // than the debounce delay, so take it as the actual current state: buttonRightState = reading; lastRightDebounceTime =millis(); }
// save the reading. Next time through the loop, // it'll be the lastButtonState: lastButtonRightState = reading;
//Up button // read the state of the switch into a local variable: reading = digitalRead(buttonPinLeft);
// If the switch changed, due to noise or pressing: if (reading != lastButtonLeftState) { // reset the debouncing timer lastLeftDebounceTime = millis(); }
if ((millis() - lastLeftDebounceTime) > debounceDelay) { // whatever the reading is at, it's been there for longer // than the debounce delay, so take it as the actual current state: buttonLeftState = reading; lastLeftDebounceTime=millis();; }
// save the reading. Next time through the loop, // it'll be the lastButtonState: lastButtonLeftState = reading;
//records which button has been pressed if (buttonEnterState==HIGH){ lastButtonPushed=buttonPinEnter;
}else if(buttonEscState==HIGH){ lastButtonPushed=buttonPinEsc;
}else if(buttonRightState==HIGH){ lastButtonPushed=buttonPinRight;
}else if(buttonLeftState==HIGH){ lastButtonPushed=buttonPinLeft;
}else{ lastButtonPushed=0; } }
void navigateMenus() { MenuItem currentMenu=menu.getCurrent();
switch (lastButtonPushed){ case buttonPinEnter: if(!(currentMenu.moveDown())){ //if the current menu has a child and has been pressed enter then menu navigate to item below menu.use(); }else{ //otherwise, if menu has no child and has been pressed enter the current menu is used menu.moveDown(); } break; case buttonPinEsc: menu.toRoot(); //back to main break; case buttonPinRight: menu.moveRight(); break; case buttonPinLeft: menu.moveLeft(); break; }
lastButtonPushed=0; //reset the lastButtonPushed variable }
[/quote]
