problema con modulo rc522
Premetto che ho rivisto tutti i post precedenti sull’argomento, controllato e ricontrollato saldature e collegamenti,ho provato diverse librerie, ho utilizzato due arduino diversi (un nano e un UNO) e il mio sospetto e che il modulo non funziona.
Questo e l’ultimo sketc che ho utilizzato dagli esempi della libreria:
 * Example sketch/program to test your firmware.
 * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
 * This example test the firmware of your MFRC522 reader module, only known version can be checked. If the test passed
 * it do not mean that your module is faultless! Some modules have bad or broken antennas or the PICC is broken.
 * NOTE: for more informations read the README.rst
 * @author Rotzbua
 * @license Released into the public domain.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_PIN          10         // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
 * Check firmware only once at startup
  Serial.begin(9600);   // Initialize serial communications with the PC
  while (!Serial);      // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  SPI.begin();          // Init SPI bus
  mfrc522.PCD_Init();   // Init MFRC522 module
  Serial.println(F("*****************************"));
  Serial.println(F("MFRC522 Digital self test"));
  mfrc522.PCD_DumpVersionToSerial();  // Show version of PCD - MFRC522 Card Reader
  Serial.println(F("-----------------------------"));
  Serial.println(F("Only known versions supported"));
  Serial.println(F("Performing test..."));
  bool result = mfrc522.PCD_PerformSelfTest(); // perform the test
  Serial.print(F("Result: "));
  if (result)
    Serial.println(F("OK"));
    Serial.println(F("DEFECT or UNKNOWN"));
void loop() {} // nothing to do
Questo è il risultato del test:
Firmware Version: 0xFF = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
Performing test…
Sto utilizzando un modulo come questo:
Sapete dirmi se posso fare qualche altra prova per verificare il funzionamento del modulo?
