Buon giorno.
Scrivo per chiedere aiuto e info.
Vi posto lo sketch che l'azienda fornisce per la comunicazione seriale tra il diplay e arduino.
Premetto che l'azienda fa scaricare sul suo sito il software di configurazione per i suoi display "4D Workshop".
Lo sketch serve per comunicare con il diplay configurato con VisiGenie.
#include <genieArduino.h>
// This Demo communicates with a 4D Systems Display, configured with ViSi-Genie.
// The display has a slider, a cool gauge, an LED Digits, a string box and a User LED.
// The program receives messages from the Slider0 object using the Reported Events. This is triggered each time the Slider changes on the display, and an event
// is genereated and sent automatically. Reported Events originate from the On-Changed event from the slider itself, set in the Workshop4 software.
// Coolgauge is written to using Write Object, and the String is updated using the Write String command, showing the version of the library.
// The User LED is updated by the Arduino, by first doing a manual read of the User LED and then toggling it based on the state received back.
// As the slider changes, it sends its value to the Arduino (Arduino also polls its value using genie.ReadObject, as above), and the Arduino then
// tells the LED Digit to update its value using genie.WriteObject. So the Slider message goes via the Arduino to the LED Digit.
// Coolgauge is updated via simple timer in the Arduino code, and updates the display with its value.
// The User LED is read using genie.ReadObject, and then updated using genie.WriteObject. It is manually read, it does not use an Event.
// This demo illustrates how to use genie.ReadObject, genie.WriteObject, Reported Messages (Events), genie.WriteStr, genie.WriteContrast, plus supporting functions.
Genie genie;
#define RESETLINE 4 // Change this if you are not using an Arduino Adaptor Shield Version 2 (see code below)
// NOTE, the genieBegin function (e.g. genieBegin(GENIE_SERIAL_0, 115200)) no longer exists. Use a Serial Begin and serial port of your choise in
// your code and use the genie.Begin function to send it to the Genie library (see this example below)
Serial.begin(200000); // Serial0 @ 200000 (200K) Baud
genie.Begin(Serial); // Use Serial0 for talking to the Genie Library, and to the 4D Systems display
genie.AttachEventHandler(myGenieEventHandler); // Attach the user function Event Handler for processing events
// Reset the Display (change D4 to D2 if you have original 4D Arduino Adaptor)
// If NOT using a 4D Arduino Adaptor, digitalWrites must be reversed as Display Reset is Active Low, and
// the 4D Arduino Adaptors invert this signal so must be Active High.
pinMode(RESETLINE, OUTPUT); // Set D4 on Arduino to Output (4D Arduino Adaptor V2 - Display Reset)
digitalWrite(RESETLINE, 1); // Reset the Display via D4
delay(100);
digitalWrite(RESETLINE, 0); // unReset the Display via D4
delay (3500); //let the display start up after the reset (This is important)
//Turn the Display on (Contrast) - (Not needed but illustrates how)
genie.WriteContrast(1); // 1 = Display ON, 0 = Display OFF
//Write a string to the Display to show the version of the library used
genie.WriteStr(0, GENIE_VERSION);
static long waitPeriod = millis();
static int gaugeAddVal = 1;
static int gaugeVal = 50;
genie.DoEvents();
if (millis() >= waitPeriod)
// Write to CoolGauge0 with the value in the gaugeVal variable
genie.WriteObject(GENIE_OBJ_COOL_GAUGE, 0x00, gaugeVal);
gaugeVal += gaugeAddVal;
if (gaugeVal == 99) gaugeAddVal = -1;
if (gaugeVal == 0) gaugeAddVal = 1;
// The results of this call will be available to myGenieEventHandler() after the display has responded
// Do a manual read from the UserLEd0 object
genie.ReadObject(GENIE_OBJ_USER_LED, 0x00);
waitPeriod = millis() + 50; // rerun this code to update Cool Gauge and Slider in another 50ms time.
// This is the user's event handler. It is called by genieDoEvents()
// when the following conditions are true
// The link is in an IDLE state, and
// There is an event to handle
// The event can be either a REPORT_EVENT frame sent asynchrounously
// from the display or a REPORT_OBJ frame sent by the display in
// response to a READ_OBJ request.
/*COMPACT VERSION HERE, LONGHAND VERSION BELOW WHICH MAY MAKE MORE SENSE
void myGenieEventHandler(void)
genieFrame Event;
int slider_val = 0;
const int index = 0; //HARD CODED TO READ FROM Index = 0, ie Slider0 as an example
genieDequeueEvent(&Event);
//Read from Slider0 for both a Reported Message from Display, and a Manual Read Object from loop code above
if (genieEventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_SLIDER, index) ||
genieEventIs(&Event, GENIE_REPORT_OBJ, GENIE_OBJ_SLIDER, index))
slider_val = genieGetEventData(&Event); // Receive the event data from the Slider0
genieWriteObject(GENIE_OBJ_LED_DIGITS, 0x00, slider_val); // Write Slider0 value to to LED Digits 0
//LONG HAND VERSION, MAYBE MORE VISIBLE AND MORE LIKE VERSION 1 OF THE LIBRARY
genieFrame Event;
genie.DequeueEvent(&Event);
int slider_val = 0;
//If the cmd received is from a Reported Event (Events triggered from the Events tab of Workshop4 objects)
if (Event.reportObject.cmd == GENIE_REPORT_EVENT)
if (Event.reportObject.object == GENIE_OBJ_SLIDER) // If the Reported Message was from a Slider
if (Event.reportObject.index == 0) // If Slider0
slider_val = genie.GetEventData(&Event); // Receive the event data from the Slider0
genie.WriteObject(GENIE_OBJ_LED_DIGITS, 0x00, slider_val); // Write Slider0 value to to LED Digits 0
//If the cmd received is from a Reported Object, which occurs if a Read Object (genie.ReadOject) is requested in the main code, reply processed here.
if (Event.reportObject.cmd == GENIE_REPORT_OBJ)
if (Event.reportObject.object == GENIE_OBJ_USER_LED) // If the Reported Message was from a User LED
if (Event.reportObject.index == 0) // If UserLed0
bool UserLed0_val = genie.GetEventData(&Event); // Receive the event data from the UserLed0
UserLed0_val = !UserLed0_val; // Toggle the state of the User LED Variable
genie.WriteObject(GENIE_OBJ_USER_LED, 0x00, UserLed0_val); // Write UserLed0_val value back to to UserLed0
//This can be expanded as more objects are added that need to be captured
//Event.reportObject.cmd is used to determine the command of that event, such as an reported event
//Event.reportObject.object is used to determine the object type, such as a Slider
//Event.reportObject.index is used to determine the index of the object, such as Slider0
//genie.GetEventData(&Event) us used to save the data from the Event, into a variable.
Questi sono gli errori che l'IDE mi da nel momento in cui faccio la verifica
Arduino:1.5.6-r2 (Windows 7), Scheda:"Arduino Uno"
genieArduino_Demo:17: error: 'Genie' does not name a type
genieArduino_Demo.ino: In function 'void setup()':
genieArduino_Demo:25: error: 'genie' was not declared in this scope
genieArduino_Demo:43: error: 'GENIE_VERSION' was not declared in this scope
genieArduino_Demo.ino: In function 'void loop()':
genieArduino_Demo:52: error: 'genie' was not declared in this scope
genieArduino_Demo:57: error: 'GENIE_OBJ_COOL_GAUGE' was not declared in this scope
genieArduino_Demo:64: error: 'GENIE_OBJ_USER_LED' was not declared in this scope
genieArduino_Demo.ino: In function 'void myGenieEventHandler()':
genieArduino_Demo:104: error: 'genieFrame' was not declared in this scope
genieArduino_Demo:104: error: expected `;' before 'Event'
genieArduino_Demo:105: error: 'genie' was not declared in this scope
genieArduino_Demo:105: error: 'Event' was not declared in this scope
genieArduino_Demo:110: error: 'GENIE_REPORT_EVENT' was not declared in this scope
genieArduino_Demo:112: error: 'GENIE_OBJ_SLIDER' was not declared in this scope
genieArduino_Demo:117: error: 'GENIE_OBJ_LED_DIGITS' was not declared in this scope
genieArduino_Demo:123: error: 'GENIE_REPORT_OBJ' was not declared in this scope
genieArduino_Demo:125: error: 'GENIE_OBJ_USER_LED' was not declared in this scope
Questo report potrebbe essere più ricco
di informazioni con
"Mostra un output dettagliato durante la compilazione"
abilitato in "File > Impostazioni"
Sembra che non venga riconosciuta la libreria inserita all'inizio, genieArduino.h, o forse non viene riconosciuto l'oggetto Genie.
Qualcuno può gentilmente aiutarmi a capire perchè non funziona?
Quì il sito dell'azienda con i riferimenti al software e le librerie usate: http://www.4dsystems.com.au/product/Development/4D_Workshop_4_IDE/
Grazie mille per il vostro aiuto.
