problema con unir dos sketch en arduino mega 2560
Try to join two sketch the keyboard example and blink without delay the latter as a function that I call A (), to try to do a multitasking, but it does not work inside the IF, if I only put it if it works, how to do so Work within the IF, thank you very much. I hope someone helps me, due to the little knowledge in programming, this is the code:
#include <Keypad.h>
const int ledPin = 15; // the number of the LED pin
// Variables will change :
int ledState = LOW; // ledState used to set the LED
// Generally, you should use “unsigned long” for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won’t change :
const long interval = 1000; // interval at which to blink (milliseconds)
int st;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{ 1, 5, 9, 13},
{ 2, 6, 10, 14},
{ 3, 7, 11, 15},
{ 4, 8, 12, 16},
/* {‘0’,‘1’,‘2’,‘3’},
{‘4’,‘5’,‘6’,‘7’},
{‘8’,‘9’,‘A’,‘B’},
{‘C’,‘D’,‘E’,‘F’}
byte rowPins[ROWS] = {38, 40, 42, 44};//connect to the row pinouts of the keypad
byte colPins[COLS] = {46, 48, 50, 52}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void a() {
// here is where you’d put code that needs to be running all the time.
// check to see if it’s time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
pinMode(ledPin, OUTPUT);
char customKey = customKeypad.getKey();
if (customKey) {//!= NO_KEY){
st = customKey;
Serial.print(“tecla:”);
Serial.print(customKey);
Serial.print("");
Serial.print("tecla: ");
Serial.println(st);
a();
