surbyte:
Sigue esta guía
Mechatronics and Robotics Engineering for Advanced and Intelligent Manufacturing
tampoo llego a nada solo puede ver q cuando aplico AT + BAUD2 no tengo mas comunicacion (pase todo a 38400 pero nada, cuando la flasheo no tirando
#include <SoftwareSerial.h>
#define BUFFER_LENGTH 100
SoftwareSerial ble(10, 11); // For Uno, HM10 TX pin to Arduino Uno pin D2, HM10 RX pin to Arduino Uno pin D3
//SoftwareSerial ble(10,11); // For Mega 2560, HM10 TX pin to Arduino Mega 2650 pin D10, HM10 RX pin to Arduino Mega 2560 pin D11
char buffer[BUFFER_LENGTH]; // Buffer to store response
int timeout = 800; // Wait 800ms each time for BLE to response, depending on your application, adjust this value accordingly
long bauds[] = {300, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 74880, 115200, 230400, 250000, 500000, 1000000}; // common baud rates, when using HM-10 module with SoftwareSerial, try not to go over 57600
long BLEAutoBaud() {
int baudcount = sizeof(bauds) / sizeof(long);
for (int i = 0; i < baudcount; i++) {
for (int x = 0; x < 3; x++) { // test at least 3 times for each baud
Serial.print("Testing baud ");
Serial.println(bauds*);*
_ ble.begin(bauds*);_
_ if (BLEIsReady()) {_
_ return bauds;
return -1;
boolean BLEIsReady() {
BLECmd(timeout, "AT" , buffer); // Send AT and store response to buffer*
* if (strcmp(buffer, "OK") == 0) {
return true;
return false;
}_
_boolean BLECmd(long timeout, char command, char* temp) {
* long endtime;
boolean found = false;
endtime = millis() + timeout; //
memset(temp, 0, 100); // clear buffer*
* found = true;
Serial.print("Arduino send = ");
Serial.println(command);
ble.print(command);
// The loop below wait till either a response is received or timeout*
* // The problem with this BLE Shield is most of the HM-10 modules do not response with CR LF at the end of the response,
// so a timeout is required to detect end of response and also prevent the loop locking up.
while (!ble.available()) {
if (millis() > endtime) { // timeout, break*
* found = false;
if (found) { // response is available*
* int i = 0;
while (ble.available()) { // loop and read the data*
* char a = ble.read();
// Serial.print((char)a); // Uncomment this to see raw data from BLE*
temp = a; // save data to buffer
* i++;_
if (i >= BUFFER_LENGTH) break; // prevent buffer overflow, need to break*
* delay(1); // give it a 2ms delay before reading next character*
* Serial.print("BLE reply = ");*
* Serial.println(temp);*
* while ((strlen(temp) > 0) && ((temp[strlen(temp) - 1] == 10) || (temp[strlen(temp) - 1] == 13)))*
* temp[strlen(temp) - 1] = 0;*
* return true;*
* } else {*
* Serial.println("BLE timeout!");*
* return false;*
* Serial.begin(115200);*
* pinMode(13, OUTPUT);*
* digitalWrite(13, LOW);*
* // If you see lots of BLE timeout on Serial Monitor after BLEAutoBaud completed, most likely your have a bad shield*
* // Check if the shield JUMPER is correctly set to*
* // HM10 TX to D2*
* // HM10 RX to D3*
* long baudrate = BLEAutoBaud();*
* if (baudrate > 0) {*
* Serial.print("Found BLE baud rate ");*
* Serial.println(baudrate);*
* } else {*
* Serial.println("No BLE detected.");*
* while (1) {}; // No BLE found, just going to stop here*
* // The following commands are just to demonstrate the shield is working properly,*
* // in actual application, only call those that are needed by your application.*
* // Check HM-10 datasheet for the description of the commands.*
* BLECmd(timeout, "AT+NAME?", buffer);*
* BLECmd(timeout, "AT+BAUD?", buffer);*
* BLECmd(timeout, "AT+MODE?", buffer);*
* BLECmd(timeout, "AT+PASS?", buffer);*
* BLECmd(timeout, "AT+VERS?", buffer);*
* BLECmd(timeout, "AT+RADD?", buffer);*
* BLECmd(timeout, "AT+ADDR?", buffer);*
* BLECmd(timeout, "AT+TYPE?", buffer);*
* BLECmd(timeout, "AT+POWE?", buffer); // Show power (should be 2 or 3)*
* BLECmd(timeout, "AT+NOTI?", buffer); // Check the current notification bit*
* BLECmd(timeout, "AT+NOTI0", buffer); // Make sure the module doesn't send AT+CONNECT or AT+LOST on the serial line*
* // BLECmd(timeout,"AT+NAMEHM10",buffer); // Set the name of the module to HM10*
* // BLECmd(timeout,"AT+BAUD0",buffer); // Set baudrate to 9600*
* // BLECmd(timeout,"AT+BAUD1",buffer); // Set baudrate to 19200*
* // BLECmd(timeout,"AT+BAUD2",buffer); // Set baudrate to 38400*
* // BLECmd(timeout,"AT+BAUD3",buffer); // Set baudrate to 57600*
* // BLECmd(timeout,"AT+BAUD4",buffer); // Set baudrate to 115200*
* Serial.println("----------------------");*
* Serial.println("Waiting for remote connection...");*
void printhex(unsigned char c)
* if (c < 0x10) {*
* Serial.print("0");*
* Serial.print(c, HEX);*
* if (ble.available()) {*
* char c = (char)ble.read();*
* if (isPrintable(c))*
* Serial.print(c);*
* else*
* Serial.print("[");*
* printhex(c);*
* Serial.print("]");*
* if (c == '1') digitalWrite(13, HIGH); // if received character 1 from BLE, set PIN 13 high*
* if (c == '0') digitalWrite(13, LOW); // if received character 0 from BLE, set PIN 13 low*
pasa a responder en 9600 a la las preguntas AT q les hace pero despues no responde mas, y entre las respuestas veo que en AT+NOTI da 0 (desactivado) le mando un AT+NOTI1 pero sigue sin responder y no me aplica el cambio
