Problema de programación
Hola!!
Estoy utilizando un programa que duerme y despierta a Digimesh. Le he puesto un contador llamado "contador" :slight_smile: pero se reinicia cada vez que se duerme el Digimesh... alguien me podría echar una mano??
Gracias!!!
#include <avr/sleep.h>
int sensor1 = 1;
int sensor3 = 3;
int val1 = 1;
int val3 = 3;
int wakePin = 2; // pin used for waking up
int sleepStatus = 0; // variable to store a request for sleep
int count = 0; // counter
int led = 13;
int contador=0;
void wakeUpNow() // here the interrupt is handled after wakeup
pinMode(wakePin, INPUT);
pinMode(led, OUTPUT);
Serial.begin(19200);
/* Now is time to enable a interrupt. In the function call
  • attachInterrupt(A, B, C)
  • A can be either 0 or 1 for interrupts on pin 2 or 3.
  • B Name of a function you want to execute while in interrupt A.
  • C Trigger mode of the interrupt pin. can be:
  • LOW a low level trigger
  • CHANGE a change in level trigger
  • RISING a rising edge of a level trigger
  • FALLING a falling edge of a level trigger
  • In all but the IDLE sleep modes only LOW can be used.
attachInterrupt(0, wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
// wakeUpNow when pin 2 gets LOW
void sleepNow() // here we put the arduino to sleep
/* Now is the time to set the sleep mode. In the Atmega8 datasheet
  • http://www.atmel.com/dyn/resources/prod_documents/doc2486.pdf on page 35
  • there is a list of sleep modes which explains which clocks and
  • wake up sources are available in which sleep modus.
  • In the avr/sleep.h file, the call names of these sleep modus are to be found:
  • The 5 different modes are:
  • SLEEP_MODE_IDLE -the least power savings
  • SLEEP_MODE_ADC
  • SLEEP_MODE_PWR_SAVE
  • SLEEP_MODE_STANDBY
  • SLEEP_MODE_PWR_DOWN -the most power savings
  • For now, we want as much power savings as possible, so we
  • choose the according
  • sleep modus: SLEEP_MODE_PWR_DOWN
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
sleep_enable(); // enables the sleep bit in the mcucr register
// so sleep is possible. just a safety pin
/* Now is time to enable a interrupt. we do it here so an
  • accidentally pushed interrupt button doesn't interrupt
  • our running program. if you want to be able to run
  • interrupt code besides the sleep function, place it in
  • setup() for example.
  • In the function call attachInterrupt(A, B, C)
  • B Name of a function you want to execute at interrupt for A.
  • LOW a low level triggers
  • CHANGE a change in level triggers
  • RISING a rising edge of a level triggers
  • FALLING a falling edge of a level triggers
attachInterrupt(0,wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
sleep_mode(); // here the device is actually put to sleep!!
// THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
sleep_disable(); // first thing after waking from sleep:
// disable sleep...
detachInterrupt(0); // disables interrupt 0 on pin 2 so the
// wakeUpNow code will not be executed
// during normal running time.
// function to send data
void sendData(int id,int num, int data1, int data3, int contador){
Serial.print("@");
Serial.print(id);
Serial.print("|");
Serial.print(num);
Serial.print("|data1-");
Serial.print(data1);
Serial.print("|data3-");
Serial.print(data3);
Serial.print("|contador-");
Serial.print(contador);
Serial.println("#\r"); // end of message
val1 = analogRead(sensor1);
val3 = analogRead(sensor3);
sendData(1,count, val1, val3, contador);
count++;
contador++;
if (count >= 10000){ // reset the counter after 10000
count = 0;
delay(100);
// sleep again
sleepNow();
has probado a declarar tu contador como volatile?
/d
