Problema emisor y receptor NRF24L01
Hola,
Estoy construyendo un drone y decidí construir mi control a distancia y el receptor a partir de dos placas Arduino NANO y dos módulos NRF24L01. El receptor emite una señal PPM que la controladora de uelo del drone descifra. Mi problema es que pese que a veces consigo establecer una conexión y que la controladora reciba la señal a través del receptor. Cuando lo vuelvo a encender el receptor ya no recibe nada. Alguien puede ayudarme?
Código del receptor:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define channel_number 7
#define sigPin 2
#define PPM_FrLen 27000
#define PPM_PulseLen 400
int ppm[channel_number];
const uint64_t My_radio_pipeIn = 0xE8E8F0F0E1LL;
RF24 radio(9, 10);
struct Received_data {
  byte ch1;
  byte ch2;
  byte ch3;
  byte ch4;
  byte ch5;
  byte ch6;
  byte ch7;
Received_data received_data;
void reset_received_Data()
  received_data.ch1 = 0;
  received_data.ch2 = 127;
  received_data.ch3 = 127;
  received_data.ch4 = 127;
  received_data.ch5 = 0;
  received_data.ch6 = 0;
  received_data.ch7 = 0;
  PPM_width_Values();
void PPM_width_Values()
  ppm[0] = map(received_data.ch1,   0, 255, 1000, 2000);
  ppm[1] = map(received_data.ch2,   0, 255, 1000, 2000);
  ppm[2] = map(received_data.ch3,   0, 255, 1000, 2000);
  ppm[3] = map(received_data.ch4,   0, 255, 1000, 2000);
  ppm[4] = map(received_data.ch5,   0, 1, 1000, 2000);
  ppm[5] = map(received_data.ch6,   0, 1, 1000, 2000);
  ppm[6] = map(received_data.ch7,   0, 255, 1000, 2000);
  pinMode(sigPin, OUTPUT);
  digitalWrite(sigPin, 0);
  cli();
  TCCR1A = 0;
  TCCR1B = 0;
  OCR1A = 100;
  TCCR1B |= (1 << WGM12);
  TCCR1B |= (1 << CS11);
  TIMSK1 |= (1 << OCIE1A);
  sei();
  reset_received_Data();
  radio.begin();
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.openReadingPipe(1,My_radio_pipeIn);
  radio.startListening();
unsigned long lastRecvTime = 0;
void receive_the_data()
  while ( radio.available() ) {
  radio.read(&received_data, sizeof(Received_data));
  lastRecvTime = millis(); //Here we receive the data
  receive_the_data();
  PPM_width_Values();
  unsigned long now = millis();
  if ( now - lastRecvTime > 1000 ) {
#define clockMultiplier 2
ISR(TIMER1_COMPA_vect){
  static boolean state = true;
  TCNT1 = 0;
  if ( state ) {
    PORTD = PORTD & ~B00000100;
    OCR1A = PPM_PulseLen * clockMultiplier;
    state = false;
  else {
    static byte cur_chan_numb;
    static unsigned int calc_rest;
    PORTD = PORTD | B00000100;
    state = true;
    if(cur_chan_numb >= channel_number) {
      cur_chan_numb = 0;
      calc_rest += PPM_PulseLen;
      OCR1A = (PPM_FrLen - calc_rest) * clockMultiplier;
      calc_rest = 0;
    else {
      OCR1A = (ppm[cur_chan_numb] - PPM_PulseLen) * clockMultiplier;
      calc_rest += ppm[cur_chan_numb];
      cur_chan_numb++;
Código del transmisor:
#include <SPI.h>
#include <RF24.h>
const uint64_t my_radio_pipe = 0xE8E8F0F0E1LL;
RF24 radio(9, 10);
struct Data_to_be_sent {
  byte ch1;
  byte ch2;
  byte ch3;
  byte ch4;
  byte ch5;
  byte ch6;
  byte ch7;
Data_to_be_sent sent_data;
  radio.begin();
  radio.openWritingPipe(my_radio_pipe);
  sent_data.ch1 = 127;
  sent_data.ch2 = 127;
  sent_data.ch3 = 127;
  sent_data.ch4 = 127;
  sent_data.ch5 = 0;
  sent_data.ch6 = 0;
  sent_data.ch7 = 0;
  sent_data.ch1 = map( analogRead(A0), 0, 1024, 255, 0);
  sent_data.ch2 = map( analogRead(A1), 0, 1024, 0, 255);
  sent_data.ch3 = map( analogRead(A2), 0, 1024, 0, 255);
  sent_data.ch4 = map( analogRead(A3), 0, 1024, 0, 255);
  sent_data.ch5 = digitalRead(2);
  sent_data.ch6 = digitalRead(3);
  sent_data.ch7 = map( analogRead(A4), 0, 1024, 0, 255);
  radio.write(&sent_data, sizeof(Data_to_be_sent));
Gracias por su tiempo!
Código receptor.zip (2.87 KB)
Código transmisor.zip (1.85 KB)
Que tipo de nrf24 tienes?
Link al producto
Diagrama de conexión?
Aqui te adjunto el link del producto:
Y los diagramas de connexión
Receptor:
D2 --> salida de la connexión PPM
D9--> CE
D10--> CSN
D11--> MOSI
D12--> MISO
D13--> CLK
Transmisor:
A0--> Potenciómetro 1
A1--> Potenciómetro 2
A2--> Potenciómetro 3
A3--> Potenciómetro 4
D9--> CE
D10--> CSN
D11--> MOSI
D12--> MISO
D13--> CLK
Por favor @guillem_palmes lee Normas del foro y edita tu enlace y ten presente como se postea códigos, enlaces e imágenes.
No hay muchos nRF24, basicamente con y sin antena. Hacer un dron sin antena creo que es una pérdida de tiempo. Asi que ya sabemos que NRF24 usas.
Estas usando un AMS1117 para crear los 3.3V que requiere o como lo alimentas? Hablo del nRF24 y además, le pusiste el capacitor (ya hablaremos del valor) entre 3.3V y GND?
Ya lo he puesto todo en orden.
Correcto, uso uno con antena para tener más rango.
Sí, estoy usando un AMS1117 para crear los 3.3V. También estoy usando un capacitador de 10μF entre 3.3V y GND
Una con antena no. Los dos
A uno con antena me refería al modelo. Obviamente les he puesto antena a los dos.
Entonces Houston tenemos un probelma!!
Dices que arrancan bien y luego que haces, apagas uno y ahi se pierde la conexión?
Los nRF24 con antena suelen dar dolores de cabeza, no se porque pero es una consulta repetida.
Voy a probar luego tu código y te digo.
Me va a llevar un tiempo asi que tal vez mañana te responda.
El resumen es que me ha funcionados dos veces y des de entonces ha muerto. Ya he intentado con un reset, he vuelto a subir los programas a las placas y he aumentado el voltaje que subministraba al transmisor.
10 uF es demasiado poco. Mínimo 220uF, mejor 470uF, en ambos módulos.
Los módulos del enlace se puede usar principalmente para radio control de un drone, si realmente están con amplificador (el segundo IC). Pero no lo recomiendo. Si ha de ir a más de 50m exterior, siempre optaría por una solución comprada.
Hace poco había aquí un hilo sobre nrf24 falsificados. No estaría demás si buscaras este hilo para verificar si los tuyos son con circuitos integrales originales.
Okay. Compraré los de mayor capacidad y comprobaré si era eso o es el modulo que no funciona.
Gràcias
