Salve, stò per diventare pazzo a causa di un display Lcd collegato ad un LCD backpanel acquistato su Hobbytronics un LCD Backpanel che funziona un giorno si e l'altro no!!
il Display è quello dell'arduino starter kit:
e questo è il Backpanel:
http://www.hobbytronics.co.uk/lcd/i2clcd-backpack-v2
Il Codice che ho usato e che ieri funzionava l'ho preso dal pdf consigliato sempre su Hobbytronics:
I2CLCD
Example Arduino sketch to communicate with HobbyTronics I2CLCD backpack
The I2CLCD backpack turns a standard HD44780 LCD display into an I2C addressable
Device which will free up many pins for use elsewhere.
Requires the Hobbytronics HTI2CLCD library
Copyright (c) 2011 www.hobbytronics.co.uk
This example code is in the public domain.
#include <Wire.h>
#include <HTI2CLCD.h> // Include the Library
HTI2CLCD lcd; // Create an instance of the HTI2CLCD
const int lcd_address=58; // I2C Address of LCD backpack
unsigned long counter=0;
int bl=0; // Backlight power value
unsigned long currentTime;
unsigned long bloopTime;
unsigned long cloopTime;
byte updown=0;
// We can create up to 8 of our own characters to display
// Here we define 2 characters to be uploaded
byte ht_logo[8] = {
B10100,
B10100,
B11111,
B10110,
B10110,
B00010,
B00010,
byte smiley[8] = {
B00000,
B10001,
B00000,
B00000,
B10001,
B01110,
B00000,
delay(800); // Give LCD time to configure itself
Wire.begin(); // join i2c bus
lcd.setType(lcd_address,4,20); // Define rows and columns for LCD
lcd.createChar(lcd_address,0, ht_logo); // Upload ht_logo as character 0
lcd.createChar(lcd_address,1, smiley); // Upload smiley as character 1
lcd.clear(lcd_address); // Clear LCD
lcd.backLight(lcd_address,10); // Set backlight to dim
// Display String
lcd.write(lcd_address,0); // Display our ht_logo character
lcd.print(lcd_address," HobbyTronics ");
lcd.write(lcd_address,1); // Display our smiley character
currentTime = millis();
cloopTime = currentTime;
bloopTime = currentTime;
if(currentTime >= (cloopTime + 1000)){
// Create String with Text and Number
lcd.setCursor(lcd_address,2,1);
char ascii[32];
sprintf(ascii,"Counter: %0.7d",counter);
lcd.print(lcd_address,ascii);
counter++;
cloopTime = currentTime; // Updates cloopTime
if(currentTime >= (bloopTime + 30)){
// Lets increase the brightness until we hit 150, then we reduce back to 0 again
if(updown==0) bl++;
else bl--;
if(bl==150) updown=1;
if(bl==0) updown=0;
lcd.backLight(lcd_address,bl);
bloopTime = currentTime; // Updates bloopTime
Il problema è che non si accende più il Display, non credo sia un problema di collegamento è talmente stupido che ci arrivo pure io, in pratica:
- Arduino pin 5v --> 5v pin backpack
- Arduino pin GND --> GND pin backpack
- Arduino pin A4 --> SDA pin backpack
- Arduino pin A5 --> SCL pin backpack
come potete vedere dalla foto sotto:
l'unica cosa che mi da da pensare è che poco dopo aver visto che il display funzionava ho provato a collegare un MCP23017, non vorrei che si sia verificato un conflitto di "IC2 adress"
ho fatto una prova con questo IC2 Scanner
http://playground.arduino.cc/Main/I2cScanner
ma non trova nessun collegamento IC2. =(
Non sò più dove sbattere la testa, consigli?
