Problema interfacciamento nRF8001 con Arduino Ethernet
Salve a tutti.
Sto cercando di interfacciare il modulo bluetooth nRF8001 di Adafruit con arduino ethernet board. Il modulo utilizza l’interfaccia SPI per comunicare con arduino. Dopo aver collegato tutto come indicato sul sito di Adafruit e dopo aver caricato l’esempio della libreria, mi accorgo che l’nRF8001 non viene riconosciuto.
Per esempio, nello sketch di esempio di Adafruit:
This is an example for our nRF8001 Bluetooth Low Energy Breakout
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/1697
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Kevin Townsend/KTOWN  for Adafruit Industries.
MIT license, check LICENSE for more information
All text above, and the splash screen below must be included in any redistribution
// This version uses the internal data queing so you can treat it like Serial (kinda)!
#include <SPI.h>
#include "Adafruit_BLE_UART.h"
// Connect CLK/MISO/MOSI to hardware SPI
// e.g. On UNO & compatible: CLK = 13, MISO = 12, MOSI = 11
#define ADAFRUITBLE_REQ 10
#define ADAFRUITBLE_RDY 3     // This should be an interrupt pin, on Uno thats #2 or #3
#define ADAFRUITBLE_RST 9
Adafruit_BLE_UART BTLEserial = Adafruit_BLE_UART(ADAFRUITBLE_REQ, ADAFRUITBLE_RDY, ADAFRUITBLE_RST);
    Configure the Arduino and start advertising with the radio
void setup(void)
  while(!Serial); // Leonardo/Micro should wait for serial init
  Serial.println(F("Adafruit Bluefruit Low Energy nRF8001 Print echo demo"));
  // BTLEserial.setDeviceName("NEWNAME"); /* 7 characters max! */
  BTLEserial.begin();
  pinMode(2,OUTPUT);
  digitalWrite(2,LOW);
    Constantly checks for new events on the nRF8001
aci_evt_opcode_t laststatus = ACI_EVT_DISCONNECTED;
  // Tell the nRF8001 to do whatever it should be working on.
  BTLEserial.pollACI();
  // Ask what is our current status
  aci_evt_opcode_t status = BTLEserial.getState();
  // If the status changed....
  if (status != laststatus) {
    // print it out!
    if (status == ACI_EVT_DEVICE_STARTED) {
        Serial.println(F("* Advertising started"));
    if (status == ACI_EVT_CONNECTED) {
        Serial.println(F("* Connected!"));
    if (status == ACI_EVT_DISCONNECTED) {
        Serial.println(F("* Disconnected or advertising timed out"));
    // OK set the last status change to this one
    laststatus = status;
    // Lets see if there's any data for us!
    if (BTLEserial.available()) {
      Serial.print("* "); Serial.print(BTLEserial.available()); Serial.println(F(" bytes available from BTLE"));
    // OK while we still have something to read, get a character and print it out
    while (BTLEserial.available()) {
      char c = BTLEserial.read();
      Serial.print(c);
    // Next up, see if we have any data to get from the Serial console
    if (Serial.available()) {
      // Read a line from Serial
      Serial.setTimeout(100); // 100 millisecond timeout
      String s = Serial.readString();
      // We need to convert the line to bytes, no more than 20 at this time
      uint8_t sendbuffer[20];
      s.getBytes(sendbuffer, 20);
      char sendbuffersize = min(20, s.length());
      Serial.print(F("\n* Sending -> \"")); Serial.print((char *)sendbuffer); Serial.println("\"");
      // write the data
      BTLEserial.write(sendbuffer, sendbuffersize);
dovrebbe uscire “Advertising started” sul monitor seriale, cosa che invece non succede.
Suppongo sia un problema di comunicazione SPI, poiché arduino utilizza gli stessi pin per comunicare con il chip ethernet.
Chiedo un consiglio a voi che sicuramente ne capite più di me.
Grazie!!
guida di Adafruit: Introduction | Getting Started with the nRF8001 Bluefruit LE Breakout | Adafruit Learning System
Rinnoviamo l'invito a presentarti (dicci quali conoscenze hai di elettronica e di programmazione) qui: Presentazioni e a leggere il regolamento: Regolamento - qui una serie di schede by xxxPighi per i collegamenti elettronici vari: ABC - Arduino Basic Connections - qui le pinout delle varie schede by xxxPighi: Pinout - qui una serie di link [u]generali[/u] utili: Link Utili
Fatto. :wink:
Stai usando lo spesso Pin di ChipSelect della scheda ethernet.
Devi spostarlo ( sia come assegnazione che come collegamento ) su un'altro pin libero ( il 4 e' già usato dall'SD )
tamaracili:
Fatto. :wink:
Grazie ;D
