Problema LCD 20X4
Salve a tutti, avrei bisogno di una mano nel far funzionare un display 20x4 che nn ne vuole sapere :o
Mi spiego meglio… ho seguito tutta la guida alla lettera http://arduino.cc/en/Tutorial/LiquidCrystal naturalmente sostituendo 16, 2 con 20, 4
caricato questo codice:
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
#include <Wire.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
appena avviato Arduino si illuminano solo la prima e terza riga, dopodiche tutte e 4 le righe si intravedono (sembra come se fossero pronte a scrivere) ma nulla, rimangono cosi´
ps: ho 2 Arduino e 2 Display 20x4 ma entrambi con il medesimo problema
help :-X
Per esperienza, gli lcd 20x4 non sono uno standard mondiale. Ovvero dipende da quale chip grafico montano e soprattutto da chi lo ha costruito. A volte i pin sono diversi da modello a modello, quindi non è detto che questo:
vada bene per il tuo modello. Hai un link a dove hai comprato il display ?
P.S. i pin al display sono saldati vero ? Non sono cavetti volanti !?!
I pin sono saldati e cmq sulla scheda c’è la nomenclatura che ho verificato e corrisponde con le note del programma e sul datasheet che ho trovato in rete
Osservazione banale: hai provato a regolare il contrasto?
A me un problema simile è capitato con il primo lcd 16x2 che ho avuto tra le mani, si accendeva ma non si vedeva nulla.
Ho scoperto poi che avevo il contrasto a 0 e quindi i caratteri erano troppo sbiaditi per essere visibili.
Ti allego lo schema di collegamento di un 16x2 a cui ho aggiunto anche un potenziometro per regolare la luminosità. Per il 20x4 non dovrebbe cambiare nulla, comunque controlla la disposizione dei pin sul tuo lcd.
Ciao
Attilio
Il contrasto va bene, è la prima cosa che ho controllato, provando con altri codici di esempio, ho notato che si intravede sfarfallio, ma niente....
I pin gli ho controllati e ricontrollato, sono ok
Ciao
stavo dando uno sguardo allo sketch che hai postato e mi sorge un dubbio:
prima dell'istruzione lcd.print("hello, world!") io ci vedrei bene una istruzione lcd.setCursor(colonna, riga) per dirgli da dove iniziare a stampare.
Per esempio:
  lcd.begin(20, 4);
  lcd.setCursor(0, 1);   //posiziona il cursore a colonna 0 e riga 1
Prova e vedi se va.
Attilio
Provato anche scrivendo su tutte le righe ma nulla…
Io ho usato queste librerie e questi consigli: http://arduino-info.wikispaces.com/LCD-Blue-I2C https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/schematics#!i2c-connection
Appena vado a casa provo
Provato ma nulla…
nid ma i tuoi link sono per I2C, lui lo sta usando in parallelo quindi semplicemente con l'hello word della libreria integrata nell'ide deve funzionare. Purtroppo dal retro dell'LCD non si leggono i nomi dei chip, hai almeno il datasheet ? Se non e' un problema di collegamento deve per forza essere un lcd che usa ic diversi dal classico HD44780
Vero @testato mi son confuso con un altro thread. Comunque secondo me la libreria di fmalpartida è meglio di quella standard, gestisce i vari tipi di collegamento, da parallelo a i2c: https://bitbucket.org/fmalpartida/new-liquidcrystal/src
@joe, hai un link a dove l'hai comprato ?
Quei display li uso a vagonate e vanno benissimo (li compro su Banggood.com)
Li uso in I2C con la FANTASTICA libreria di Testato !!!
A questo punto mi interessa vedere tutti i collegamenti tra LCD e Arduino.
grazie :)
