problema libreria irremote
salve sono due giorni che ho problemi con questa libreria... ho cercato problemi analoghi sul forum tipo dove hanno risolto aggiornando l'ide e la libreria ma dopo averlo fatto l'errore è cambiato... prima non trovava un file ora dice che le variabili non sono dichiarate; questo è l'errore:
Arduino:1.5.6-r2 (Windows 7), Scheda:"Arduino Due (Programming Port)"
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::mark(int)':
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:227: error: 'TCCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:227: error: 'COM2B1' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:227: error: '_BV' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::space(int)':
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:235: error: 'TCCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:235: error: 'COM2B1' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:235: error: '_BV' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::enableIROut(int)':
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:253: error: 'TIMSK2' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: 'TCCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: 'WGM20' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: '_BV' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: 'TCCR2B' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: 'WGM22' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: 'CS20' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: 'OCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:263: error: 'OCR2B' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::enableIRIn()':
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:274: error: 'cli' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:279: error: 'TCCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:279: error: 'WGM21' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:279: error: '_BV' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:279: error: 'TCCR2B' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:279: error: 'CS21' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:279: error: 'OCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:279: error: 'TCNT2' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:282: error: 'TIMSK2' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:282: error: 'OCIE2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:282: error: '_BV' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:286: error: 'sei' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp: In function 'void TIMER2_COMPA_vect()':
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:370: error: 'PORTB' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\IRremote\IRremote.cpp:373: error: 'PORTB' was not declared in this scope
qualcuno ha qualche suggerimento???
p.s. ho aggiornato l'ide all'ultima versione e uso arduino due... sono alle prime armi e sto cercando di scoprire un pò la libreria irremote
grazie
Non mi risulta che la IRremote sia compatibile con Arduino DUE ...
... credo ne esista un'altra, con nome simile, modificata per la DUE ... QUI qualche cosa ... :roll_eyes:
Guglielmo
Confermo che la IRRemote NON è compatibile con la Due.
allora ci stavo anche anni senza risolvere niente grazie mille :slight_smile: mi avete salvato XD
niente l'ho provata poco fa e niente neanche con la libreria per il due =(
WARNING: library Robot IR Remote claims to run on [avr] architecture(s) and may be incompatible with your current board which runs on [sam] architecture(s).
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp: In member function 'void IRrecv::enableIRIn()':
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:82: error: 'cli' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:87: error: 'TCCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:87: error: 'WGM21' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:87: error: '_BV' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:87: error: 'TCCR2B' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:87: error: 'CS21' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:87: error: 'OCR2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:87: error: 'TCNT2' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:90: error: 'TIMSK2' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:90: error: 'OCIE2A' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:90: error: '_BV' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:94: error: 'sei' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp: In function 'void TIMER2_COMPA_vect()':
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:178: error: 'PORTB' was not declared in this scope
C:\Users\Pierfra\Desktop\arduino-1.5.6-r2\libraries\RobotIRremote\src\IRremote.cpp:181: error: 'PORTB' was not declared in this scope
l'ho riscaricata e ricaricata e ora va :confused: mah comunque grazie mille
