Hola a todos!
Estoy haciendo una interfaz con una pantalla nextion de 2.4", el diseño y el control de botones lo tengo controlado, pero no consigo enviar datos de arduino a la pantalla nextion.
Para descartar problemas en mi proyecto he usado un ejemplo que acompaña a la libreria oficial de la pantalla (GitHub - itead/ITEADLIB_Arduino_Nextion), el codigo de ejemplo es el siguiente:
* @example CompText.ino
* @par How to Use
* This example shows that ,when the "+" component on the Nextion screen is released,
* the value of text component will plus 1,when the "-" component released ,the value of
* text component will minus 1 every time.
* @author Wu Pengfei (email:<pengfei.wu@itead.cc>)
* @date 2015/7/10
* @updated 2016/12/25 bring HMI up to v0.32 to avoid too old issues
* @convert by Patrick Martin, no other changes made
* @copyright
* Copyright (C) 2014-2015 ITEAD Intelligent Systems Co., Ltd. \n
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
#include "Nextion.h"
void t0PopCallback(void *ptr);
void b0PopCallback(void *ptr);
void b1PopCallback(void *ptr);
* Declare a text object [page id:0,component id:1, component name: "t0"].
NexText t0 = NexText(0, 1, "t0");
* Declare a button object [page id:0,component id:2, component name: "b0"].
NexButton b0 = NexButton(0, 2, "b0");
* Declare a button object [page id:0,component id:3, component name: "b1"].
NexButton b1 = NexButton(0, 3, "b1");
char buffer[100] = {0};
* Register object t0, b0, b1, to the touch event list.
NexTouch *nex_listen_list[] =
&t0,
&b0,
&b1,
NULL
* Text component pop callback function.
dbSerialPrintln("t0PopCallback");
t0.setText("50");
* Button0 component pop callback function.
* In this example,the value of the text component will plus one every time when button0 is released.
uint16_t len;
uint16_t number;
dbSerialPrintln("b0PopCallback");
memset(buffer, 0, sizeof(buffer));
t0.getText(buffer, sizeof(buffer));
number = atoi(buffer);
number += 1;
itoa(number, buffer, 10);
t0.setText(buffer);
* Button1 component pop callback function.
* In this example,the value of the text component will minus one every time when button1 is released.
uint16_t len;
uint16_t number;
dbSerialPrintln("b1PopCallback");
number -= 1;
t0.setText(buffer);
void setup(void)
/* Set the baudrate which is for debug and communicate with Nextion screen. */
nexInit();
/* Register the pop event callback function of the current text component. */
t0.attachPop(t0PopCallback);
/* Register the pop event callback function of the current button0 component. */
b0.attachPop(b0PopCallback);
/* Register the pop event callback function of the current button1 component. */
b1.attachPop(b1PopCallback);
dbSerialPrintln("setup done");
void loop(void)
* When a pop or push event occured every time,
* the corresponding component[right page id and component id] in touch event list will be asked.
nexLoop(nex_listen_list);
El error es que no se refresca la informacion en la pantalla y en la salida serial encuentro el siguiente mensaje de error a cada pulsacion de los botones.
19:18:49.742 -> [1073670532:0,2,b0]
19:18:49.742 -> b0PopCallback
19:18:49.777 -> get t0.txt⸮⸮⸮recvRetString[0,]
19:18:49.847 -> t0.txt="1"⸮⸮⸮recvRetCommandFinished err
19:18:49.952 -> [1073670532:0,2,b0]
19:18:49.985 -> b0PopCallback
19:18:50.020 -> get t0.txt⸮⸮⸮recvRetString[0,]
19:18:50.089 -> t0.txt="1"⸮⸮⸮recvRetCommandFinished err
19:18:52.145 -> [1073670508:0,3,b1]
19:18:52.145 -> b1PopCallback
19:18:52.180 -> get t0.txt⸮⸮⸮recvRetString[0,]
19:18:52.248 -> t0.txt="65535"⸮⸮⸮recvRetCommandFinished err
19:18:52.560 -> [1073670508:0,3,b1]
19:18:52.560 -> b1PopCallback
19:18:52.594 -> get t0.txt⸮⸮⸮recvRetString[0,]
19:18:52.664 -> t0.txt="65535"⸮⸮⸮recvRetCommandFinished err
Se os ocurre que pueda estar haciendo mal o que este mal en el ejemplo?
CompText_v0_32.ino (3.38 KB)
