buenas tardes! tengo el siguiente error:
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detectando las librerías usadas...
C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880\sketch\Blink.ino.cpp -o C:\Users\Acosta's\AppData\Local\Temp\3569427543\sketch_merged.cpp
C:\Users\Acosta's\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Acosta's\AppData\Local\Temp\3569427543\sketch_merged.cpp
Compilando el sketch...
"C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino" "-IC:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard" "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880\sketch\Blink.ino.cpp" -o "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880\sketch\Blink.ino.cpp.o"
Compilando librerías...
Compilando el núcleo...
Using precompiled core: C:\Users\Acosta's\AppData\Local\arduino\cores\arduino_avr_uno_af0121bc77a9d80853af174a05ec7a21\core.a
Linking everything together...
"C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/Blink.ino.elf" "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880\sketch\Blink.ino.cpp.o" "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/..\..\cores\arduino_avr_uno_af0121bc77a9d80853af174a05ec7a21\core.a" "-LC:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880" -lm
"C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/Blink.ino.elf" "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/Blink.ino.eep"
"C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/Blink.ino.elf" "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/Blink.ino.hex"
"C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/Blink.ino.elf"
El Sketch usa 924 bytes (2%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 9 bytes (0%) de la memoria dinámica, dejando 2039 bytes para las variables locales. El máximo es 2048 bytes.
"C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM9" -b115200 -D "-Uflash:w:C:\Users\Acosta's\AppData\Local\arduino\sketches\BFF06A13DBBA67E7D3A5788AEF0F1880/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Acosta's\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't set com-state for "\.\COM9"
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
tenia este problema con una placa arduprofe, ahora compre otro arduino uno y tampoco funciona. me podrian ayudar?
